Upgrade path according to specification
alberto.douglas
I need  help to determine what the most recent version of this server I
can upgrade them to
here are the description and specification of each one
CUCM Version                  7.1.3.32900-4
CUCM Platform                MCS-7816-H3-CCX1/PC1 74-5013-01 (7816H3)
CCM Processor:                Celeron D @3200Mhz
CCM RAM:                          2.00 GB
thanks
2 Accepted Solutions
You can review such information here:
Supported Servers for Releases of Cisco Unified  Communications Manager (including Business Edition 3000 / 5000 / 6000  and Session Manager Edition) and Cisco Intercompany Media Engine
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
I'd doublecheck that model because CCX1 means Contact Center and those are not suported for CUCM in any version.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
All the information and links are available on CCO
Software and Hardware Compatibility Guide for Cisco Unified CCX and Cisco Unified IP IVR (September 30, 2011)
www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_compatibility/matrix/crscomtx.pdf
Cisco Unity Supported Platforms List
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps2237/product_data_sheet0900aecd802132ef.html
Hardware and Software Compatibility Information for Cisco Unified Presence Release 8.0, 8.5 and 8.6
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cups/8_0/english/compatibility/cupcompatibility8x.html
java
java
alberto.douglas
I would like to go over version 8 if its possible according to the specification of hardware I have
java
java
Javalenc<
what a about link to check this:
Cisco Unity Version         7.0 Build 7.0(2)
                CUPS Version                    7.0.4.10000-18
                UCCX Version                    7.0(1)SR5_Build504
java
java
