05-27-2008 08:33 AM - edited 03-15-2019 10:54 AM
Hello I have two CCM 5.1.3 PUB and Sub. I need to upgraded to cisco-ipt-k9-patch5.1.3.3000-5.tar.gz.sgn anyone tell me step-to- step how to do the upgraded.
Thanks.
Solved! Go to Solution.
05-27-2008 10:56 AM
go thru the Release Notes for the upgrade you plan to apply, all the upgraded components are listed there
javalenc
if this helps, please rate
05-27-2008 09:02 AM
Thanks for reply I need to knows if need first that PUB staring completely so once that pub this in it online now starting with Sub.
Can you help me?
05-27-2008 09:06 AM
Please be so kind to read the steps i posted, what you're asking (reboot order) is there
javalenc
