IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5766 Views
  • 14 replies
hi folks,i have two callmanagers and we are using h.323 gateways with gatekeeper.the calls from one cisco phone registered to callmanager1 to outside mobile phone doesn't play any announcement when the mobile is not available.while if i use the phone...
Hi there,I am trying to use BAT to check the following box on the phones"logged into hunt group"I do update phones and select the box and run the job.I get the following error when we run the jobHLOGcolumn not found in table devicewe get this on each...
I have just configured presence on 3 phones using CallManager 5.0.4. I have a 7960 with BLF/Speed dials configured and working just fine. I thought you should be able to see BLF status when you look at Missed Calls and the corporate directory. This i...
Hi All, I am trying to download IOS for 2821 router, when I press the download link in feature natigator page, I got the error in the buttom of the web page "undetermine string constant". is it something from Cisco side or related to my browser? alth...
Hi I ran DMA yesterday night ant he gave me some warnings with all the username. They have been configured with underscore. Example frederick_gouger Does somebody knows of I can go with the upgrade on a new server at 6.1 or I really have to change al...
f.gouger by Level 1
  • 398 Views
  • 5 replies
phone type: 7942Version of Callmanager: 5.1.3.2000-3Version of firmware: 8.3(3)In the Device configuration for a 7942G phone there is no option to enable the hookswitch feature.Could someone verify if this feature is supposed to be available in 5.1(3...
