Upgrading from Onramp10 to Onramp30- MGCP voice gateway - configuraiton
alalli
Level 2
Level 2
Hi All,
We are upgrading from Telstra Onramp10 to Onramp30 for our voice gateway.
The router is MGCP controlled.
I was looking through the Gateway CUCM ver 7.1 screens and did not see any reference to the amount of timeslots given on the ISDN service.
I might only need to make the change on the router.
Can anyone confirm?
thanks so much
alalli
The configuration on the router will look like this:
controller E1 x/x/x
pri-group timeslots 1-10,16 service mgcp
new router configuration for the Onramp30 will be :
controller E1 x/x/x
pri-group timeslots 1-31 service mgcp
Dennis Mink
yes correct,
put in
controller E1 0/0/0
You might need to reset the MGCP GW in CUCM
for onramp30,  you should see all your serial interface available if you do a sh ip int br.  so ser0/0/0:0-0/0/0:30.
make sure you have enough DSP's in the router when you upgrade.
Please remember to rate useful posts, by clicking on the stars below.
