Upgrading IP Phone 7971
Hello guys,
pls help me with this problem cause till now i didn't find any solution.... here we go
i have 3 IP PHONE 7971 all of them SCCP i want to change to SIP i made the tftp dhcp server ip pool 192.168.1.33  router  192.168.1.1 alredey tried option 150 & 66 i put in the network 192.168.1.1 and point the option 66 with 192.168.1.33 when start the tftp i got this logs
Client requested address 0.68.101.112 [28/09 04:08:06.400]
DHCP: proposed address 192.168.1.33 [28/09 04:08:18.458]
Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 00:1E:F7:28:96:92 [28/09 04:08:18.459]
Client requested address 0.68.101.112 [28/09 04:08:18.460]
DHCP: proposed address 192.168.1.33 [28/09 04:08:30.459]
Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 00:1E:F7:28:96:92 [28/09 04:08:30.460]
Client requested address 0.68.101.112 [28/09 04:08:30.460]
DHCP: proposed address 192.168.1.33 [28/09 04:08:42.458]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:1E:F7:28:96:92
Client requested address 192.168.1.33 which was not allocated by tftpd32 and is either outside our pool or is used by someone else [28/09 04:13:56.617]
the XMLDefault.cnf.xml config as fallow :
# <Default> #
# </members> #
# </callManagerGroup> #
# <loadInformation30006 model="Cisco 7971">sip70.8-0-4SR1S</loadInformation30006> #
# </Default> #
the boot screen still showing upgrading and nothing happend ......
also 2 of them when i started the sequence number went to dark screen looks like off
no one ? can answer me ?
post the output of debug tftp event
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:1E:F7:28:96:92 [28/09 04:16:23.460] Client requested address 192.168.1.34 which was not allocated by tftpd32 and is either outside our pool or is used by someone else [28/09 04:16:23.460] Freeing item 192.168.1.34 46:46:3A:46:46:3A [28/09 04:17:36.401] Message truncated (length was 8) [28/09 04:17:36.402] Freeing item 192.168.1.35 00:1E:F7:28:96:92 [28/09 04:17:38.409] Message truncated (length was 8) [28/09 04:17:38.410] Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:1E:F7:28:96:92 [28/09 04:19:22.699] Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:1E:F7:28:96:92 [28/09 04:19:26.683] Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:1E:F7:28:96:92 [28/09 04:19:34.684] Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:1E:F7:28:96:92 [28/09 04:19:50.685] Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:1E:F7:28:96:92 [28/09 04:20:22.686] Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 00:1E:F7:28:96:92 [28/09 04:21:26.701] Client requested address 0.68.101.112 [28/09 04:21:26.702] DHCP: proposed address 192.168.1.34 [28/09 04:21:38.459] Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 00:1E:F7:28:96:92 [28/09 04:21:38.460] Client requested address 0.68.101.112 [28/09 04:21:38.460] DHCP: proposed address 192.168.1.34 [28/09 04:21:50.458] Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:1E:F7:28:96:92 [28/09 04:21:50.459] Previously allocated address 192.168.1.34 acked [28/09 04:22:02.458] Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:1E:F7:28:96:92 [28/09 04:22:02.459] Suppress pingable address 192.168.1.34 [28/09 04:22:05.571] Previously allocated address 192.168.1.35 acked [28/09 04:22:17.458] Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:1E:F7:28:96:92 [28/09 04:22:17.459] Client requested address 192.168.1.34 which was not allocated by tftpd32 and is either outside our pool or is used by someone else [28/09 04:22:17.459]
