Upgrading pvdm on 2811 router with adipservice 12.4(22)t
hassan.saleh
how can i update the firmware of the pvdm on a 2811 router that have a 12.4(22)T ios.
and from where can i download the upgrade software
5 Replies 5
paolo bevilacqua
There is no firmware for pvdm to upgrade.
To download IOS updates, you have to buy a support contract first.
i have did it previously on an older ios.
but on this ios i can't
Please listen to who talks with experience.
It's not needed, and not possible.
Hassan,
Are you using Digital Modem PVDM Module? If yes -
Q. How can I get the firmware version on the modems?
A. The modem firmware is bundled with Cisco IOS Software; you can find the version using the following command-line interface (CLI): "show modem version". You can also upgrade the firmware using the "modem firmware slot" CLI.
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/ps5882/qa_c67_541965_ps5855_Products_Q_and_A_Item.html
If you are using DSP PVDM modules, then no.
-> Sushil
Hi Hassan,
It is possible to upgrade the DSPware for PVDMs. However, this is a last-resort tactic we use in TAC and is absolutely not intended for "let's see if it solves my problem" troubleshooting. It's likely you had a TAC case and they upgraded your DSP firmware, but this is NOT something you want to do on your own.
See this document for details:
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a0080a7af82.shtml
-nick
