06-12-2016 03:36 PM - edited 03-17-2019 07:12 AM
Guys, I've downloaded International Dial Plan file.
Could you please give a hint as to how to upload it on CUCM TFTP.
Thank you.
06-12-2016 06:02 PM
You use the OS admin page to install any COP file or upload files to the TFTP.
06-19-2016 01:08 AM
Hi Jaime,
Thank you for your reply.
I followed your advice and uploaded dp-ffr.3-1-9.AU.cop.sgn from Cisco Unified OS Administration - Software Upgrades - TFTP File Management - Upload File. However, it's still unavailable in the list of Dial Plans in CIsco Unified CM Administration - Call Routing - Dial Plan Installer.
Could you please describe the process in more detail.
Thank you.
P.S. Uploaded dp-ffr.3-1-9.AU.cop.sgn is visible in the list of files in CLI but not visible in the list of TFTP files in OS Administration.
06-19-2016 10:12 AM
Because you need to install COP files, not upload them to the TFTP.
06-19-2016 03:02 PM
OK, but how do I install it? Tried Dial Plan installer but there is nothing there.
06-19-2016 03:31 PM
Hi Aakim,
You install the dial plan COP file like you install phone firmware, not upload like List.xml
JB
06-24-2016 06:05 PM
Hi guys,
I installed DP the way you advised, and it was installed successfully. According to the instructions on this link http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/idp/1001/dpdep/DPLinux.html nothing else should be done. However, it is still not available.
What could be the reason?
06-19-2016 07:34 PM
Refer to the following link for deploying Dial Plan on CUCM:
There is a section for "Installing COP File" that has the steps to install the Dial Plan COP file.
01-16-2018 03:27 PM
We have the same issue as OP.
Have installed COP file 3-1-9 as per documentation, go into Dial Plan Installer menu, not available in drop down.
