Uploading MOH Out of Space Error
Remington
Trying to upload new MOH and getting the following error message:
HTTP Status 500 -
type: Exception report
message:
description: The server encountered an internal error that prevented it from fulfilling this request.
exception:
ServletException org.apache.commons.fileupload.FileUploadException: Processing of multipart/form-data request failed. No space left on device
root cause:
FileUploadException Processing of multipart/form-data request failed. No space left on device
note: The full stack trace of the root cause is available in the logs.
However, disk utilization seems fine.
admin:show tech runtime disk
-------------------- show platform runtime --------------------
The disk usage:
Filesystem Size Used Avail Use% Mounted on
/dev/sda1 20G 12G 7.2G 63% /
/dev/sda6 68G 66G 0 100% /common
/dev/sda3 248M 11M 225M 5% /grub
/dev/sda2 20G 172M 19G 1% /partB
tmpfs 2.9G 85M 2.8G 3% /dev/shm
none 128M 0 128M 0% /var/log/ramfs/cm/trace/ccm/sdi
none 128M 6.5M 122M 6% /var/log/ramfs/cm/trace/ccm/sdl
none 128M 1.5M 127M 2% /var/log/ramfs/cm/trace/ccm/calllogs
none 128M 0 128M 0% /var/log/ramfs/cm/trace/ccm/dntrace
none 128M 6.6M 122M 6% /var/log/ramfs/cm/trace/lbm/sdl
none 128M 0 128M 0% /var/log/ramfs/cm/trace/cti/sdi
none 128M 6.5M 122M 6% /var/log/ramfs/cm/trace/cti/sdladmin:
Any suggestions on where to look next? Thanks.
0 Replies 0
