10-01-2008 10:38 AM - edited 03-15-2019 01:40 PM
I inherited a CME in London and just installed one here in the US. I have extension to extension call working, now I am trying to configure the US CME to be able to make regular calls through the London CME via our VPN. I am looking for an example config to do this.
Thanks.
10-03-2008 02:49 AM
Hi, don't know if your translation worked or not but one of the ways around this is on the UK end create a voice translation profile that 'translates' your calling US extension to have type and plan unknown.
In the following example assume that the US extensions are in the 1... range:
voice translation-rule 4
rule 1 /1.../ // type any unknown plan unknown unknown
voice translation-profile OUTBOUND
translate calling 4
dial-peer voice $$$ pots
translation-profile outgoing OUTBOUND
This has worked for me in the past when US callers are using TEHO through the UK.
Hope it helps.
10-03-2008 04:37 AM
Would that go on the UK side
10-03-2008 04:47 AM
10-03-2008 05:39 AM
If I`m right from the US you send all the digits to the UK and then the UK translates it?
It seems you have a UK translation which is any number with a type internatuional add prefix 900, or national add 90 so you end up with a number of 900901144..... or 9090...... ???????????????
Also the Dial-peer
dial-peer voice 3 pots
destination-pattern 90114420........
port 0/0/0:15
forward-digits 10
will not work either as you are sending 20XXXXXXXX when you should be sendin a prefix of 0
prefix 0
forward-digits 10
so you now send 020XXXXXXX
Depending on where you wish to do the translations my choice is the sending the switch
voice translation-rule 1
rule 1 /^901144\(*\)/ /90\1/ TYPE UNKNOWN INTERNATIONAL PLAN UNKNOWN NATIONAL ISDN
This changes the number from US international to UK with national - normally ok if not change it to unknown as well
voice translation-profile US to UK
translated called 1
dial-peer voice 11 voip
translation-profile incoming US to UK
session target IP4V X.X.X.X
10-03-2008 05:50 AM
This goes on the UK side right.
10-07-2008 01:29 AM
did my suggestions work ?
10-07-2008 04:38 AM
Yes thanks.
