User can no longer reset phones
Tom Ribbens
Hi all,
After upgrading from CUCM 7.1.5 to 8.6.2, a user can no longer reset or restart phones. He gets a Not Authorized message. This user is in a custom group, with custom role, as he only should access pages for moves/adds/changes. I browsed through the permissions page multiple times, and I can't seem to find any setting which would allow the person to reset phones.
Any help here?
Kind regards,
Tom
Rob Huffman
Hi Tom,
It sounds like this bug;
CSCug29903 Bug Details >
Reset/Apply not working for CCMAdmin with custom roles
Symptom:
Assigning custom roles to end/application user does not allow to use the Reset/Apply buttons
Hitting save, shows that the update was successful
Conditions:
CUCM 8.6.2.23068-1 or higher
User created Roles
Standard (Built-in) roles should work fine.
Workaround:
Add read/update privileges for the "Voice Mail Pilot web pages" resource to the custom role
More Info:
Status Status
Fixed
Severity Severity
3 - moderate
Last Modified Last Modified
In Last 7 Days
Product Product
Cisco Unified Communications Manager (CallManager)
Technology Technology
1st Found-In 1st Found-in
8.6(2)
Fixed-In Fixed-in
9.1(0.98000.458)
1.0(0.98000.218)
10.0(0.98000.4)
Cheers!
Rob
"I don't know how, I don't know when
But you and I will meet again "
- Tom Petty
Rob Huffman
Hi Tom,
Symptom:
Conditions:
User created Roles
Workaround:
More Info:
Status Status
Fixed
Severity Severity
3 - moderate
In Last 7 Days
Product Product
8.6(2)
Fixed-In Fixed-in
9.1(0.98000.458)
1.0(0.98000.218)
10.0(0.98000.4)
Cheers!
Rob
- Tom Petty
hanlykent
For those running 9.1 and above,
We just ran into this problem upgrading from 9.1.1 to 9.1.2 SU2 (9.1.2.12900-11)
The above workaround fixed the issue.
We did not have this issue in 9.1.1, so it seems the issue has represented itself in later versions on 9.1
