User Rank field from End user is not available from getUser/updateUser
jdrinkwater
User Rank field from End user is not available from getUser/updateUser AXL request
I couldn't find the user rank tag from xsd file. How can I set or capture the field using getUser/updateUser request?
Even I didn't find that.. Need to go through the Axl schema.
Using  below SQL Query you can  get the required informations from CLI.
run sql select userid , userrank from enduser
Response Signature
Couldn't find it from the AXL schema. I wanted to check with others before I write a new TAC case.
