Using 8841 K9 phone on an Asterisk server
gary.hicks
I am testing the ease of moving our 8841 phones over to an Asterisk server (FreePBX and Xorcom are the test platforms).  I have pulled the phone cnf file from CUCM and modified the server information to be the Xorcom server and I have set alternate TFTP address on the phone to point to the Xorcom server.
At this time all I am getting is the registering message on the phone.
The following is the cnf file.  Does anyone have suggestions on what I need to modify to get this to work?
5 Replies 5
HARIS_HUSSAIN
Refer Below links
https://community.spiceworks.com/topic/1335724-cp-8851-on-asterisk
https://www.voip-info.org/asterisk-phone-cisco-79xx/
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
Leo Laohoo
A known working SEPmacaddress.xml.cnf can be found HERE.
Thank you for the quick response.  I will try this today.
I updated the configuration file. At first, I looked on the phone and saw the status message that it could not find a .sgn file so I changed the name of the config to include that.  I am still only seeing "Phone is registering"
Attached is the current configuration file, the phone status messages, and the phone network settings.
the Xorcom Asterisk server IP address is 10.12.50.41
Did you manage fixing the issue?
please share if yes
