01-05-2014 09:08 AM - edited 03-16-2019 09:06 PM
when i perform recovery to call manager V8.6 , i noticed that this service on publisher is not running although all CDR network service are running and CDR is flagging true , i restarted the service restarted several times and restart Publisher it self but no way !!!!!!!!!!!!!!!!!
What is cause this issueu , Publisher is not send any cdr records to billing server !!!!
Amr
01-05-2014 09:36 AM
I haven't come across this specific issue but might I suggest you enable traces for the CDR Repository manager service and then see if the root cause becomes any clearer. You can enable tracing throught Unified Serviceability. Go to Trace > Configuration. Select your publishe node, then select the CDR Services Service Group, and finally select the CDR Repository Manager service.
Set your trace level to detail. Then I would restart the service (or attempt to start it) under Tools > Control Center - Network Services. This should generate some content in the trace file, which you can then view and/or download via RTMT.
Since you are doing a restore, one of the first things that comes to mind for me is related to the ipsec security certificates. I know that DRS and some other cluster functions can be affected when doing a DRS restore on a new cluster, even though the certificates from the DRS backup (previous instance of your UCM cluster) are supposed to be restored. I have resolved the DRS issues I have seen by regenerating the ipsec.cer self-signed cert and then restarting affected services. I am not sure if this is relevant for CDR Repository Manager. It is just the first thing that comes to mind.
Anyway, look at the trace files (after you elevate the trace level to detailed). You may also want to look at the application syslog (via RTMT). Somewhere in there should be some clues as to what is going on. If you have a hard time interpreting the logs/traces then post back and someone in the forum should be able to assist.
-Bill
(b) http://ucguerrilla.com
(t) @ucguerrilla
Please remember to rate helpful responses and identify helpful or correct answers.
01-05-2014 02:05 PM
Thanks William for your feedback , it was so useful and those are the generated syslogs from RTMT as following :
1) System syslog
2) Application Syslog
3) Cisco CDR Repository Syslog
all above logs generated through restarting Cisco CDR Repository Service From Network Services (But Still Not Running) .
Hope to help me where is the error ???
Amr
01-05-2014 02:45 PM
looking at your CDRRepository manager log:
2014-01-05 23:57:00,785 INFO [main] cdrrep.FileManager (FileManager.java:666) - <-- checkAndResetOwnershipAndPermission
2014-01-05 23:57:00,786 DEBUG [main] cdrrep.FileManager (FileManager.java:744) - /var/log/active/cm/cdr_repository/tmp exists
2014-01-05 23:57:00,786 FATAL [main] cdrrep.FileManager (FileManager.java:748) - /var/log/active/cm/cdr_repository/tmp is not a directory! Please remove it. System exits
my suggestion would be to raise a TAC case so cisco can access the box and the /tmp directory (as per above), using root access.
Please remember to rate useful posts, by clicking on the stars below.
