very short trunk
jemekeren
hi guys...what possible trunk can be connected between pbx and cisco router in short cable (5 meter)? is it E1/T1... ops.. by the way do we only need plain e1/t1 without kind of signal such pri? please help... beside that how dialpeer would map to this trunk? please teach me. tx very very much...
paolo bevilacqua
5m is not a problem. Please use correctly twisted cable as per pinout.
If possible at all, configure the PBX as PRI. If absolutely not possibile, tell us that choices do you have, what do you want to do, and we can suggest something.
basically i want to replace fxo cable from router to pbax port which are 20 cable/line with single trunk and i still wonder how another additional setting and dialpeer config that need modified in place of existing dialpeer. would you please helps? tx :)
Please state type of pbx use, type of interfaces on the pbx, and dialplan in use.
