VG202 PLAR
Brian Houston
Does the VG202 support the PLAR feature? My customer has successfully deployed PLAR on the VG224 platform and now needs to do the same on VG202s located on offshore rigs. Before procuring the hardware they want to be sure that the feature is supported.
Brian Houston
Brandon Pierce
Level 4
Level 4
Yes, PLAR will work as they are just FXS ports as with any other VG out there.  VG202s are End of Life though, so other than third-party vendors you won't be able to get one.  The last day of support is 2018 assuming you do get one somehow from Cisco.
