10-12-2015 11:12 AM - edited 03-18-2019 11:40 AM
VG204 Fax dials and remote fax answers but cuts off to silence after you hear fax tone for a second, below is config, and debug
Current configuration : 2675 bytes
version 12.4
no service pad
hostname adcen-vg-1flr107
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
no ip source-route
no ip cef
ip multicast-routing
no ipv6 cef
ntp server 172.20.2.100
stcapp ccm-group 10
stcapp
stcapp feature access-code
voice service voip
fax protocol none
modem passthrough nse codec g711ulaw
voice-card 0
dsp services dspfarm
archive
log config
hidekeys
interface FastEthernet0/0
ip address 172.17.1.11 255.255.0.0
ip pim sparse-mode
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
router eigrp 10
network 172.17.0.0 0.0.0.255
auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.17.1.1
ip route 0.0.0.0 0.0.0.0 172.20.1.1
no ip http server
no ip http secure-server
ip pim rp-address 172.17.1.1
ip rtcp report interval 10000
control-plane
voice-port 0/0
timeouts ringing infinity
voice-port 0/1
voice-port 0/2
voice-port 0/3
ccm-manager config server 172.11.17.1
ccm-manager sccp local FastEthernet0/0
mgcp fax t38 ecm
sccp ccm 172.11.17.1 identifier 2 priority 2 version 4.1
sccp ccm 172.11.20.1 identifier 1 priority 1 version 4.1
sccp
sccp ccm group 10
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 10 register SKIGW1AE2853A4C
registration retries 1
registration timeout 1
keepalive retries 1
keepalive timeout 3
connect retries 1
connect interval 3
switchback method graceful
dspfarm profile 12 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
associate application SCCP
shutdown
dial-peer voice 900 pots
service stcapp
port 0/0
dial-peer voice 901 pots
service stcapp
port 0/1
dial-peer voice 902 pots
service stcapp
port 0/2
dial-peer voice 903 pots
service stcapp
port 0/3
line con 0
no modem enable
line aux 0
line vty 0 4
login local
end
**************************voice port****************************
adcen-vg-1flr107#show voice port 0/0
Foreign Exchange Station 0/0 Slot is 0, Port is 0
Type of VoicePort is FXS ON-BOARD-4FXS
Operation State is DORMANT
Administrative State is UP
No Interface Down Failure
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 128 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 15 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Supervisory Disconnect Time Out is set to 750 ms
Ringing Time Out is set to infinity
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for US
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Station name None, Station number None
Translation profile (Incoming):
Translation profile (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Ring Frequency is 25 Hz
Hook Status is On Hook
Ring Active Status is inactive
Ring Ground Status is inactive
Tip Ground Status is active
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Hookflash-in Timing is set to max=1000 ms, min=150 ms
Hookflash-out Timing is set to 400 ms
No disconnect acknowledge
Ring Cadence is defined by CPTone Selection
Ring Cadence are [20 40] * 100 msec
Ringer Equivalence Number is set to 1
*************************************DEBUG**********************************
*Oct 12 18:06:22.326: //6/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x854BE038, callID=0x6, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*Oct 12 18:06:22.326: //6/C774E3D8800A/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x854BE038, Call Id=6
Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
*Oct 12 18:06:25.674: //6/C774E3D8800A/CCAPI/cc_api_call_digit_begin:
Destination Interface=0x0, Destination Mask=0x1, Destination Call Id=-1,
Source Call Id=6, Digit=7, DigitBeginFlags=0x1,
Rtp Timestamp=0xEE8259FB, Rtp Expiration=0x0
*Oct 12 18:06:25.754: //6/C774E3D8800A/CCAPI/cc_api_call_digit_end:
Source Call Id=6, Digit=7, Duration=120,
Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Call Entry(Handoff Depth=0)
*Oct 12 18:06:25.754: htsp_digit_ready(0/1): digit = 7
*Oct 12 18:06:25.754: //6/C774E3D8800A/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Tone Direction=Network, Params=0x0, Call Id=6
*Oct 12 18:06:25.758: //6/C774E3D8800A/CCAPI/ccGenerateToneInfo:
*Oct 12 18:06:29.302: //6/C774E3D8800A/CCAPI/cc_api_call_digit_begin:
Source Call Id=6, Digit=1, DigitBeginFlags=0x1,
Rtp Timestamp=0xEE82CB6E, Rtp Expiration=0x0
*Oct 12 18:06:29.382: //6/C774E3D8800A/CCAPI/cc_api_call_digit_end:
Source Call Id=6, Digit=1, Duration=117,
*Oct 12 18:06:29.382: htsp_digit_ready(0/1): digit = 1
*Oct 12 18:06:29.542: //6/C774E3D8800A/CCAPI/cc_api_call_digit_begin:
Source Call Id=6, Digit=2, DigitBeginFlags=0x1,
Rtp Timestamp=0xEE82D2EE, Rtp Expiration=0x0
*Oct 12 18:06:29.622: //6/C774E3D8800A/CCAPI/cc_api_call_digit_end:
Source Call Id=6, Digit=2, Duration=117,
*Oct 12 18:06:29.622: htsp_digit_ready(0/1): digit = 2
*Oct 12 18:06:29.782: //6/C774E3D8800A/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0xEE82DA6E, Rtp Expiration=0x0
*Oct 12 18:06:29.862: //6/C774E3D8800A/CCAPI/cc_api_call_digit_end:
*Oct 12 18:06:29.862: htsp_digit_ready(0/1): digit = 1
*Oct 12 18:06:30.022: //6/C774E3D8800A/CCAPI/cc_api_call_digit_begin:
Source Call Id=6, Digit=9, DigitBeginFlags=0x1,
Rtp Timestamp=0xEE82E1EE, Rtp Expiration=0x0
*Oct 12 18:06:30.102: //6/C774E3D8800A/CCAPI/cc_api_call_digit_end:
Source Call Id=6, Digit=9, Duration=117,
*Oct 12 18:06:30.102: htsp_digit_ready(0/1): digit = 9
*Oct 12 18:06:30.262: //6/C774E3D8800A/CCAPI/cc_api_call_digit_begin:
Source Call Id=6, Digit=4, DigitBeginFlags=0x1,
Rtp Timestamp=0xEE82E96E, Rtp Expiration=0x0
*Oct 12 18:06:30.342: //6/C774E3D8800A/CCAPI/cc_api_call_digit_end:
Source Call Id=6, Digit=4, Duration=117,
*Oct 12 18:06:30.342: htsp_digit_ready(0/1): digit = 4
*Oct 12 18:06:30.502: //6/C774E3D8800A/CCAPI/cc_api_call_digit_begin:
Source Call Id=6, Digit=6, DigitBeginFlags=0x1,
Rtp Timestamp=0xEE82F0EE, Rtp Expiration=0x0
*Oct 12 18:06:30.594: //6/C774E3D8800A/CCAPI/cc_api_call_digit_end:
Source Call Id=6, Digit=6, Duration=127,
*Oct 12 18:06:30.594: htsp_digit_ready(0/1): digit = 6
*Oct 12 18:06:30.742: //6/C774E3D8800A/CCAPI/cc_api_call_digit_begin:
Source Call Id=6, Digit=5, DigitBeginFlags=0x1,
Rtp Timestamp=0xEE82F86E, Rtp Expiration=0x0
*Oct 12 18:06:30.822: //6/C774E3D8800A/CCAPI/cc_api_call_digit_end:
Source Call Id=6, Digit=5, Duration=117,
*Oct 12 18:06:30.822: htsp_digit_ready(0/1): digit = 5
*Oct 12 18:06:30.982: //6/C774E3D8800A/CCAPI/cc_api_call_digit_begin:
Source Call Id=6, Digit=3, DigitBeginFlags=0x1,
Rtp Timestamp=0xEE82FFEE, Rtp Expiration=0x0
*Oct 12 18:06:31.062: //6/C774E3D8800A/CCAPI/cc_api_call_digit_end:
Source Call Id=6, Digit=3, Duration=117,
*Oct 12 18:06:31.062: htsp_digit_ready(0/1): digit = 3
*Oct 12 18:06:31.222: //6/C774E3D8800A/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0xEE83076E, Rtp Expiration=0x0
*Oct 12 18:06:31.302: //6/C774E3D8800A/CCAPI/cc_api_call_digit_end:
*Oct 12 18:06:31.302: htsp_digit_ready(0/1): digit = 5
*Oct 12 18:06:31.462: //6/C774E3D8800A/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0xEE830EEE, Rtp Expiration=0x0
*Oct 12 18:06:31.542: //6/C774E3D8800A/CCAPI/cc_api_call_digit_end:
*Oct 12 18:06:31.542: htsp_digit_ready(0/1): digit = 9
*Oct 12 18:06:31.702: //6/C774E3D8800A/CCAPI/cc_api_call_digit_begin:
Source Call Id=6, Digit=8, DigitBeginFlags=0x1,
Rtp Timestamp=0xEE83166E, Rtp Expiration=0x0
*Oct 12 18:06:31.794: //6/C774E3D8800A/CCAPI/cc_api_call_digit_end:
Source Call Id=6, Digit=8, Duration=127,
*Oct 12 18:06:31.794: htsp_digit_ready(0/1): digit = 8
*Oct 12 18:06:31.798: //6/C774E3D8800A/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
*Oct 12 18:06:31.798: //6/C774E3D8800A/CCAPI/ccRestartDigitTimeoutMsec:
Digit Timeout=0, Call Id=6
*Oct 12 18:06:31.798: htsp_process_event: [0/1, FXSLS_OFFHOOK, E_HTSP_PROCEEDING]
*Oct 12 18:06:33.354: //6/C774E3D8800A/CCAPI/ccCallAlert:
Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Call Entry(Responsed=TRUE, Alert Sent=TRUE)htsp_alert_notify
*Oct 12 18:06:36.394: //6/C774E3D8800A/CCAPI/ccGenerateToneInfo:
*Oct 12 18:06:36.394: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x851C3414, Interface Type=9, Destination=0.0.0.0, Mode=0x0,
Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Oct 12 18:06:36.394: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 12 18:06:36.394: :cc_get_feature_vsa malloc success
*Oct 12 18:06:36.394: cc_get_feature_vsa count is 2
*Oct 12 18:06:36.394: :FEATURE_VSA attributes are: feature_name:0,feature_time:2217029464,feature_id:7
*Oct 12 18:06:36.398: //7/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
*Oct 12 18:06:36.398: //6/C774E3D8800A/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x0
Call Entry(Connected=TRUE, Responsed=TRUE)
*Oct 12 18:06:36.398: //7/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
Interface=0x851C3414, Data Bitmask=0x0, Progress Indication=NULL(0),
Connection Handle=0
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
*Oct 12 18:06:36.398: htsp_process_event: [0/1, FXSLS_OFFHOOK, E_HTSP_CONNECT]fxsls_offhook_connect
*Oct 12 18:06:36.398: [0/1] set signal state = 0x6 timestamp = 0
*Oct 12 18:06:36.398: //6/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x84C89478, callID1=0x6, callID2=0x7, tag=0x0)
(confID=0x84C89478, callID1=0x6, gcid=C774E3D8-704211E5-800AE5FA-D4962D14, tag=0x0)
*Oct 12 18:06:36.398: //7/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x84C89478, callID2=0x7, gcid=0-0-0-0, tag=0x0)
*Oct 12 18:06:36.398: //6/C774E3D8800A/CCAPI/ccConferenceCreate:
Conference Id=0x84C89478, Call Id1=6, Call Id2=7, Tag=0x0
*Oct 12 18:06:36.398: htsp_call_bridged invoked
*Oct 12 18:06:36.402: //6/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x4, Source Interface=0x854BE038, Source Call Id=6,
Destination Call Id=7, Disposition=0x0, Tag=0xFFFFFFFF
*Oct 12 18:06:36.402: //7/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x4, Source Interface=0x851C3414, Source Call Id=7,
Destination Call Id=6, Disposition=0x0, Tag=0x0
*Oct 12 18:06:36.402: //6/C774E3D8800A/CCAPI/cc_generic_bridge_done:
*Oct 12 18:06:36.402: //6/C774E3D8800A/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x4, Destination Call Id=7)
*Oct 12 18:06:36.402: //7/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x4, Destination Call Id=6)
*Oct 12 18:06:36.402: //6/C774E3D8800A/CCAPI/cc_api_caps_ind:
Destination Interface=0x851C3414, Destination Call Id=7, Source Call Id=6,
Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
*Oct 12 18:06:36.402: //7/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
Destination Interface=0x854BE038, Destination Call Id=6, Source Call Id=7,
Caps(Codec=0x4, Fax Rate=0x1, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=2)
*Oct 12 18:06:36.402: //7/xxxxxxxxxxxx/CCAPI/cc_api_caps_ack:
Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_NONE(0x1), Vad=OFF(0x1),
Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=6243)
*Oct 12 18:06:36.402: //6/C774E3D8800A/CCAPI/cc_api_caps_ack:
*Oct 12 18:06:36.402: //6/C774E3D8800A/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x4, Call Id1=6, Call Id2=7
*Oct 12 18:06:36.406: //6/C774E3D8800A/CCAPI/cc_api_voice_mode_event:
Call Id=6
Call Entry(Context=0x0)
*Oct 12 18:06:36.406: htsp_process_event: [0/1, FXSLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxsls_voice_cut_thru
*Oct 12 18:06:36.406: //6/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0x6, digit_event=0x1, enable=TRUE, consume=FALSE)
*Oct 12 18:06:36.406: //6/C774E3D8800A/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=6
*Oct 12 18:06:36.406: //6/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
*Oct 12 18:06:36.406: //6/C774E3D8800A/CCAPI/cc_api_call_report_digits_done:
*Oct 12 18:06:36.406: //6/C774E3D8800A/CCAPI/ccCallModifyExtended:
Nominator=0x84C89420, Params=0x8343E360, Call Id=6
*Oct 12 18:06:36.410: //6/C774E3D8800A/CCAPI/ccRestartDigitTimeoutMsec:
*Oct 12 18:06:36.410: //7/xxxxxxxxxxxx/CCAPI/ccCallModify:
Nominator=0x19E08, Params=0x84C88EE0, Call Id=7
*Oct 12 18:06:36.410: //6/C774E3D8800A/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x854BE038, Call Id=6
*Oct 12 18:06:36.410: //7/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x851C3414, Call Id=7
*Oct 12 18:07:20.530: //6/C774E3D8800A/CCAPI/ccConferenceDestroy:
Conference Id=0x4, Tag=0x0
*Oct 12 18:07:20.530: //6/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=7, Disposition=0x0, Tag=0x0
*Oct 12 18:07:20.534: //7/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*Oct 12 18:07:20.534: //6/C774E3D8800A/CCAPI/cc_generic_bridge_done:
*Oct 12 18:07:20.534: //7/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Oct 12 18:07:20.538: //6/C774E3D8800A/CCAPI/ccGenerateToneInfo:
*Oct 12 18:07:20.538: //6/C774E3D8800A/CCAPI/ccCallFeature:
Feature Type=6, Call Id=6htsp_call_feature:feature 6
*Oct 12 18:07:20.538: htsp_process_event: [0/1, FXSLS_CONNECT, E_HTSP_ONHOOK_OUT]fxsls_offhook_lcfo
*Oct 12 18:07:20.538: [0/1] set signal state = 0xC timestamp = 0
*Oct 12 18:07:20.538: [0/1] set signal state = 0x4 timestamp = 750
*Oct 12 18:07:20.542: //7/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x851C3414, Tag=0x0, Call Id=7,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
*Oct 12 18:07:20.542: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 12 18:07:20.542: :cc_free_feature_vsa freeing 84252F50
*Oct 12 18:07:20.542: vsacount in free is 1
*Oct 12 18:07:20.546: //6/C774E3D8800A/CCAPI/ccCallFeature:
Feature Type=34, Call Id=6htsp_call_feature:feature 34
*Oct 12 18:07:20.546: htsp_process_event: [0/1, FXSLS_CONNECT, E_HTSP_STOP_RINGING]
*Oct 12 18:07:20.550: //6/C774E3D8800A/CCAPI/ccRestartDigitTimeoutMsec:
*Oct 12 18:07:20.550: //6/C774E3D8800A/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Internal Dial Tone,
*Oct 12 18:07:20.550: //6/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
*Oct 12 18:07:20.550: //6/C774E3D8800A/CCAPI/ccCallReportDigits:
*Oct 12 18:07:20.550: //6/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
*Oct 12 18:07:20.550: //6/C774E3D8800A/CCAPI/cc_api_call_report_digits_done:
*Oct 12 18:07:21.638: htsp_process_event: [0/1, FXSLS_CONNECT, E_DSP_SIG_0100]fxsls_offhook_onhook, HF duration Max=1000, HF duration Min=150
*Oct 12 18:07:21.642: htsp_timer - 1000 msec
*Oct 12 18:07:22.642: htsp_process_event: [0/1, FXSLS_CONNECT, E_HTSP_EVENT_TIMER]fxsls_connect_wait_release_req
*Oct 12 18:07:22.642: htsp_timer_stop
*Oct 12 18:07:22.642: //6/C774E3D8800A/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x854BE038, Call Id=6
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
*Oct 12 18:07:22.642: //6/C774E3D8800A/CCAPI/ccRestartDigitTimeoutMsec:
*Oct 12 18:07:22.642: //6/C774E3D8800A/CCAPI/ccGenerateToneInfo:
*Oct 12 18:07:22.646: //6/C774E3D8800A/CCAPI/ccGenerateToneInfo:
*Oct 12 18:07:22.646: //6/C774E3D8800A/CCAPI/ccCallFeature:
*Oct 12 18:07:22.646: //6/C774E3D8800A/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
*Oct 12 18:07:22.646: //6/C774E3D8800A/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Nullhtsp_call_feature:feature 34
*Oct 12 18:07:22.646: htsp_timer_stop3
*Oct 12 18:07:22.646: htsp_process_event: [0/1, FXSLS_WAIT_RELEASE_REQ, E_HTSP_STOP_RINGING]fxsls_stop_ringing
*Oct 12 18:07:22.646: [0/1] set signal state = 0x4 timestamp = 0
*Oct 12 18:07:22.662: htsp_process_event: [0/1, FXSLS_WAIT_RELEASE_REQ, E_HTSP_RELEASE_REQ]fxsls_waitrls_req_rls
*Oct 12 18:07:22.662: [0/1] set signal state = 0x4 timestamp = 0
*Oct 12 18:07:22.662: htsp_process_event: [0/1, FXSLS_ONHOOK, E_DSP_SIG_0100]fxsls_onhook_onhook
*Oct 12 18:07:22.666: //6/C774E3D8800A/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x854BE038, Tag=0x0, Call Id=6,
*Oct 12 18:07:22.666: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 12 18:07:22.666: :cc_free_feature_vsa freeing 84253030
*Oct 12 18:07:22.666: vsacount in free is 0
10-13-2015 01:39 AM
Instead of "fax protocol none", try "fax protocol pass-through codec g711ulaw"
GTG
10-13-2015 02:07 AM
Ive had similar issues with Faxes and the SCCP protocol.. check and make sure the codec negotiated is G711 a/ulaw.
Cheers
Ben
Please rate helpful posts.
10-14-2015 11:05 AM
Was suggested that I switch to MGCP with the following config and it worked perfectly! Just had to recreate my VG204 in call manager with the hostname as the domain name
Current configuration : 2240 bytes
version 12.4
no service pad
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
archive
log config
hidekeys
no ip mroute-cache
speed auto
full-duplex
no shutdown
no ip address
shutdown
duplex auto
speed auto
ip default-gateway 172.17.1.1
no ip http server
control-plane
voice-port 0/0
voice-port 0/1
voice-port 0/2
voice-port 0/3
ccm-manager redundant-host 172.11.20.1
ccm-manager mgcp
no ccm-manager fax protocol cisco
mgcp
mgcp call-agent 172.11.17.1 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp profile default
dial-peer voice 1 pots
service mgcpapp
port 0/0
dial-peer voice 2 pots
service mgcpapp
port 0/1
dial-peer voice 3 pots
service mgcpapp
port 0/2
dial-peer voice 4 pots
service mgcpapp
port 0/3
line con 0
no modem enable
line aux 0
line vty 0 4
login local
end
