04-22-2015 07:03 AM - edited 03-18-2019 11:30 AM
I have an extension on a VG204 port that when you try and fax from it or to it it fails. If you plug an analogue phone into the port you can make and receive calls so it is not a routing issue, this all appears to be normal. When you dial the number you get the fax tone but if you try to fax it, the fax fails.
I have disabled T38 in case this had any issues with it. I have also asked them to make sure the speed is confirmed as 9600 on the fax. The fax machine works when you move it to another GW (unfortunately a different GW as this is the only fax in that location). And when you move a working fax to that port it also fails.
Any useful suggestions?!
The only things I havent tried are cabling replacements.
04-22-2015 07:28 AM
Could you please post the config from the VG204?
04-22-2015 07:53 AM
Univ-Brad-VG204#sh run
Building configuration...
Current configuration : 2209 bytes
version 12.4
no service pad
service password-encryption
hostname Univ-Brad-VG204
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 3000000
enable secret 5 $1$8k2j$zqvnxikQkfRsbtIZQ/Nk90
aaa new-model
aaa authentication login default local
aaa session-id common
ip source-route
ip cef
no ipv6 cef
stcapp register capability 0/0 modem-passthrough
stcapp register capability 0/1 modem-passthrough
stcapp register capability 0/2 modem-passthrough
stcapp register capability 0/3 modem-passthrough
stcapp ccm-group 1
stcapp
stcapp feature access-code
stcapp feature speed-dial
voice service voip
fax protocol t38 ls-redundancy 2 hs-redundancy 0 fallback pass-through g711ulaw
modem passthrough nse codec g711ulaw
voice-card 0
username sicl privilege 15 secret 5 $1$iknK$un5H8zowF37NDU5xC5CrD0
archive
log config
hidekeys
interface FastEthernet0/0
ip address dhcp
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
control-plane
voice-port 0/0
timeouts initial 60
timeouts interdigit 60
timeouts ringing infinity
voice-port 0/1
timeouts initial 60
voice-port 0/2
timeouts initial 60
voice-port 0/3
timeouts initial 60
ccm-manager fax protocol cisco
ccm-manager config server 10.2.47.10
ccm-manager sccp local FastEthernet0/0
sccp ccm 10.2.47.10 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer voice 999020 pots
service stcapp
port 0/0
dial-peer voice 999021 pots
service stcapp
port 0/1
dial-peer voice 999022 pots
service stcapp
port 0/2
dial-peer voice 999023 pots
service stcapp
port 0/3
line con 0
no modem enable
line aux 0
line vty 0 4
exec-timeout 0 0
length 0
transport input telnet
exception data-corruption buffer truncate
end
Univ-Brad-VG204#
03-07-2024 05:16 PM
Hey,
Having the same exact problem almost a decade later on a VG450. Is there anyone who has any insight?
