vg224 call transfer problem
sunishnair
Hi i am facing issue with vg224. I am facing lot of problem with vg224. I am using sccp. some users not able to transfer the call, some of the phones not getting ring. If i check port status its showing up.
Sunish
febinattingal
Please verify you enabled vg 224 feature enabled mode.
Dear Febin,
Thanks for your support. I trouble shooted this problem. I changed the Busy settings and Call waiting options in the call manager.
Thanks and Regards,
Sunish
