04-17-2013 11:23 AM - edited 03-16-2019 04:51 PM
I need the stcapp feature speed-dial disabled, so I disabled this feature with command "no stcapp feature speed-dial" but always that this device is reloaded this feature return to default mode and it's enable again. How I fix it?
Solved! Go to Solution.
04-17-2013 12:22 PM
Hi Tiago,
This is expected behavior if you have the the "ccm-manager config" command configured. You can either disable the command or disable the speed dial feature after every reload or SCCP process restart.
You can refer to:
http://www.cisco.com/en/US/docs/ios/voice/command/reference/vr_c4.html#wp1105076
Tere.
If you find this post helpful, please rate!
04-17-2013 12:22 PM
Hi Tiago,
You can refer to:
Tere.
04-17-2013 01:29 PM
Thanks Tere,
Really the command "ccm-manager config server x.x.x.x" was setted, I'm working with SCCP so after that I remove it this issue was fixed.
Tiago
