VG310 Initial Configuration
angel-moon
Level 3
Level 3
Does anyone have a simple step by step document or video link for the initial configuration of a VG310?  For some reason the standard Cisco guides confuse me lol
All replies rated.
Thanks in advance!
piyush aghera
Please have a look at below links, they seem useful and easy to follow, though it says vg350, steps remain same for vg310:
Configuring the Command Line interface:  https://www.cisco.com/c/en/us/td/docs/routers/access/vg350/software/configuration/guide/vg350_scg/scgconf.html
Configuring Voice Ports: https://www.cisco.com/c/en/us/td/docs/routers/access/vg350/software/configuration/guide/vg350_scg/scgvoiceportCLI_ORIG.html
Configuring Next-Generation High-Density PVDM3 Modules: https://www.cisco.com/c/en/us/td/docs/routers/access/vg350/software/configuration/guide/vg350_scg/scgpvdm3_config.html
piyush aghera
If your issue is resolved, then please mark this thread as resolved.
