VIC2-2BRI-NT/TE will support DSUs - U Interface Features
Hello All,
Could you please any one advise, VIC2-2BRI-NT/TE will have capability to support DSUs (mean U interface Features) ?
mean  1-Port HWIC-1B-U is designed to support  U interface with single pair wire (RJ-48C connector) , but same line can be used to connect with VIC2-2BRI-NT/TE  cards?
Thanks in advance!!
best regards,
Naveen
Mohammed Khan
Hi Naveen,
To configure the VIC2-2BRI-NT/TE as an N/T device (U interface) use below command
"isdn layer1-emulate network"
MK
Hi Mohammed,
Thanks a lot your advise & support.
The cabling is only one pair, could you please advise i need to use VIC2-2BRI-NT/TE - RJ 48 pin 4 & 5. k.
best regards,
Naveen
