Dears....Good MorningI install ATA190 (1.2.1 ) within CUCM 9.1.2 ...I need to Disable the secure call tone indicator...Anyone can help !!!!Note: I change the specs of G3 Tones file , but this didn't affect the tone....Thanks for allRaed
Hi All,We have Lync 2010 deployment at one of our customers and we are installing CUCILync 11.6.When we are searching for a user from the CUCILync windows we can find every user and select to which phone to call for that person.But if we are looking ...
Hello , how can I determine the maximum number of meetme calls at one time? I have 3 server . One of the servers on vmware and two server on physical server. my version of cucm 8.6.2.21900-5.
Question regarding the possible restructure of our UC voice network. Current UC Implementation: Cisco Unified Communications 8.6.x DIDs/DNs are assigned to a respective SIP trunk that terminates at the gateway (ISR router) located at each branch off...
Dear all, I try to deploy LSC certificate on Cisco phone trough CME, but on the phone I can see “LSC : Not installed”. But the secure SCCP is working, but i just want to have LSC certificat eon my phone for EAP-TLS with LSC certificate. Tested w...
Hi all, I am trying to configure SMTP notification, so that users can get a notification email that they have VM on thier inbox.I am going to user --> edit--> Notification devices--> SMTP. In to field I am giving email ID : bob@xyz.comBut when I giv...
We have integrated our CUCM 8.0 with Vocalcom callcenter, when an agent initiates a call from the Vocalcom client software (which is intalled on the agent PC) to a customer outside in PSTN, the called party can't hear the voice of the agent, but the ...
Hi Guys, I need some advice: We have a customer that is deploying a new IWAN topology and would also like to run IP telephony on top of this infrastructure. Its a pretty huge setup with approx. 40 locations however some of the locations doesn't have ...
Hello all, My telephone provider requires to change the PAID (P-Asserted-Identity) SIP Header field, in order to present a different CLID, else only the default number is allowed. I have manage to change all the internal numbers (2XXX) to a speci...
Hi, In a customer network setup, has installed CUCM 8.6.2.24901-1 version. Also they have CUE 8.6.1 for voicemail (CUE is in Cisco 2921 ISM module). There are 3 Cisco 2921 routers are located in three offices (Head Office, Site 1 , Site 2). Cisco 292...
How would I set up 2 phones (6712 & 2503) so they can Pick Up their Nite bell (2504) which rings on the wall in front of them? We are using UCM 10.5 and the phones I am setting it up on are cisco model 7841. The Nite Bell is on an Analog port. See sc...
I am wondering if anyone knows how to configure speed dial numbers on 'Different' types of Cisco phones? Currently, I have 7800 SIP, 7900 SCCP model of phones. All the documentation so far I have found, talks about 'Same' type of phone. Thanks
Has anyone ever configured VWIC MFT 1-Port E1/T1, 2811 router. The router is currently installed in Mexico, and we are trying to connect to PSTN. The provider is Telmex. The gateway is configured via MGCP.Here is a part of the config:network-clock-pa...
Hi! I would like to seek for your help. I would like to know if there's a way to generate a report or to know when was the last time that the Cisco Phone was registered on call manager or when was the last time that the call manager can contacted th...
Hi We have Cisco Call Manager 10.5 and our clients use Cisco IP Communicator. We have a problem while holding a call, some times when a client holds a call for a minute, the resume button disappears and then the call disconnects ( I have attached the...
| Subject | Author | Posted |
| 03-25-2025 06:06 AM | ||
| 03-21-2025 01:42 PM | ||
| 03-20-2025 05:12 AM | ||
| 03-19-2025 06:53 AM | ||
| 03-18-2025 05:41 AM |
| User | Count |
| 5 | |
| 2 | |
| 2 | |
| 1 | |
| 1 |
