Visual Voicemail to Audio Voicemail Conversion Not working .
Abhishek Singh
Problem Description ::: Facing an issue with the Unity Connection  "Visual Voicemail" to "Audio Voicemail Conversion" . User wants to change his voicemail message from his phone. logs in to voicemail – defaulted to visual voicemail – and then tries to switch to the audio voicemail. It looks like it is switching -- voicemail connected state comes up comes on the phone -- but there is no audio.
Cisco Unity Connection version: 8.5.1ES102.15900-102.
Phone type : 7942
Needed to confirm if this is due to the bug ID : bug CSCtc94879   or bug ID : CSCtc73842 . Also if I am not wrong -- does downgrading the phone firmware
"SCCP42.9-2-3S"  to  "SCCP42.8-5-2S" .
Appreciate some quick guidance on this.  Tried using this documentation ::
http://www.cisco.com/en/US/products/ps6509/products_tech_note09186a0080b14d12.shtml -- but was not able to derive much out of it .
- Abhishek Singh
Whatever level you reach getting better never stops -- Sachin Tendulkar
Abhishek Singh
Would appreciate any help on this as this for a very critical user at the client's end.
