voice gateway h.323 port change.
rapperjky
hi all
we need change h.323 port number of voicegateway
so do you have any config?
CUCM(7.X) ------ voicegateway(2811 or 2911)
it is for security
plz help me
thank you,
3 Accepted Solutions
phooghen
You cannot change the H.323 port (TCP 1720) number.
Joseph Martini
In call manager go to Device > Gateway and under the H323 gateway configuration page there is a setting "Signaling Port" which you can change from 1720 to anything you want (make sure it doesn't overlap with something CUCM is already using, here's the port usage doc:
http://www.cisco.com/en/US/customer/docs/voice_ip_comm/cucm/port/8_0_2/portlist802.html).
I'll lookup the IOS side command to change the port number and get back to you.
5 Replies 5
phooghen
Joseph Martini
On your dial-peers you can set a port in the session target ipv4:x.x.x.x:
http://www.cisco.com/en/US/docs/ios/voice/command/reference/vr_s02.html#wp1273665
Joemar2,
I din't know it was possible to change the TCP port number but now I now know it's possible.
I give you a 5 rating.
Pierre.
hi joemar2
thank you.
i will try ^^.
