Voice gateway not able to Make outbound calls from 8x8
Aryaka Employee
We have a SIP trunk from 8x8 and there is a voip link to provider..
When we make outbound calls from 8x8 to US number via the Voice gateway the call is failing.. Incoming is working fine.
Please find the below debug message.. Can you please help me fix this..
Jan 22 09:58:32.540: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname i bucket 16 c_hname Call-ID bucket 14
Jan 22 09:58:32.540: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname f bucket 13 c_hname From bucket 4
Jan 22 09:58:32.540: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname t bucket 8 c_hname To bucket 11
Jan 22 09:58:32.540: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname l bucket 0 c_hname Content-Length bucket 8
Jan 22 09:58:32.540: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname v bucket 10 c_hname Via bucket 15
Jan 22 09:58:32.540: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:911669228XXXX@182.75.YY.XXX:5060;user=phone SIP/2.0
i: bMh2G6iLd5Hd
f: "SIP  TEST" <sip:142442XXXX4@8.20.XX.YY:6055>;tag=bUhFAeO2PZA9K
t: <sip:911669228XXXX@8.28.0.71:8115>;tag=423A8120-E62
CSeq: 1286567370 ACK
Max-Forwards: 70
User-Agent: eSLEE/0.13.98.6
l: 0
v: SIP/2.0/UDP 8.28.0.71:8115;branch=z9hG4bKaqWF5Lq6BhAd
Jan 22 09:58:32.544: //3543923/6F15278C9A23/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x13684C28, Tag=0x0, Call Id=3543923,
   Call Entry(Disconnect Cause=102, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jan 22 09:58:32.544: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 22 09:58:32.544: :cc_free_feature_vsa freeing 1256E350
Jan 22 09:58:32.544:  vsacount in free is 0
Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname f bucket 13 c_hname From bucket 4
Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname i bucket 16 c_hname Call-ID bucket 14
Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname t bucket 8 c_hname To bucket 11
Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname k bucket 18 c_hname Supported bucket 7
Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname l bucket 0 c_hname Content-Length bucket 8
Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname c bucket 10 c_hname Content-Type bucket 13
Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname x bucket 12 c_hname Session-Expires bucket 16
Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname m bucket 1 c_hname Contact bucket 11
Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname v bucket 10 c_hname Via bucket 15
Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:911669228XXXX@182.75.YY.XXX:5060;user=phone SIP/2.0
CSeq: 1286749321 INVITE
f: "SIP  TEST" <sip:142442XXXX4@8.20.XX.YY:6055>;tag=bF1uQiuSRLMcK
i: bUMBus4xMTUj
Max-Forwards: 70
k: timer, histinfo
l: 318
Remote-Party-ID: "SIP  TEST" <sip:142442XXXX4@8.20.XX.YY:6055>;party=calling;privacy=off
User-Agent: Packet8/1.2.134.11 (outaryaka248) eSLEE/0.13.98.6
c: application/sdp
x: 1893
m: <sip:bH3fKmtdFUq5gVDhUId@8.28.0.71:8115>
v: SIP/2.0/UDP 8.28.0.71:8115;branch=z9hG4bKaPjvpZq2iyf
v=0
o=VOC-Mac 0 0 IN IP4 172.17.16.72
s=-
c=IN IP4 117.20.40.200
t=0 0
m=audio 31682 RTP/AVP 110 102 0 8 101
a=rtpmap:110 opus/48000/2
a=fmtp:110 maxplaybackrate=16000;sprop-maxcapturerate=16000;maxaveragebitrate=20000
a=rtpmap:102 iLBC/8000
a=fmtp:102 mode=20
a=rtpmap:101 telephone-event/8000
a=ptime:20
SIP: (3543925) Attribute mid, level 1 instance 1 not found.
Jan 22 10:00:30.737: //3543925/DB88F73E9A2A/SIP/Error/sipSPI_ipip_copy_sdp_to_channelInfo:
failed to update call entry
Jan 22 10:00:30.737: //3543925/DB88F73E9A2A/SIP/Error/sipSPI_ipip_copy_sdp_to_channelInfo: Unable to find the proper instance for FMTP
SIP: (3543925) fmtp attribute, level 1 instance 0 not found.
Jan 22 10:00:30.737: //3543925/DB88F73E9A2A/SIP/Error/sipSPI_ipip_copy_sdp_to_channelInfo: Unable to acquire event mask for rfc2833 dtmf relay
Jan 22 10:00:30.737: //3543925/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
   Call Entry Is Not Found
Jan 22 10:00:30.737: //-1/DB88F73E9A2A/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=142442XXXX4
   ----- ccCallInfo IE subfields -----
   cisco-ani=142442XXXX4
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=911669228XXXX
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jan 22 10:00:30.737: //-1/DB88F73E9A2A/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x13684C28, Call Info(
   Calling Number=142442XXXX4,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=911669228XXXX(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=3543925
Jan 22 10:00:30.737: //-1/DB88F73E9A2A/CCAPI/ccCheckClipClir:
   In: Calling Number=142442XXXX4(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=142442XXXX4(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 22 10:00:30.737: :cc_get_feature_vsa malloc success
Jan 22 10:00:30.737:  cc_get_feature_vsa count is 1
Jan 22 10:00:30.737: :FEATURE_VSA attributes are: feature_name:0,feature_time:373291416,feature_id:2380043
Jan 22 10:00:30.737: //3543925/DB88F73E9A2A/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=142442XXXX4(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=911669228XXXX(TON=Unknown, NPI=Unknown))
Jan 22 10:00:30.737: //3543925/DB88F73E9A2A/CCAPI/cc_process_call_setup_ind:
   Event=0x1E72738
Jan 22 10:00:30.737: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 911669228XXXX
Jan 22 10:00:30.737: //3543925/DB88F73E9A2A/CCAPI/ccCallSetContext:
   Context=0x16AD9DC0
   >>>>CCAPI handed cid 3543925 with tag 1 to app "_ManagedAppProcess_Default"
Jan 22 10:00:30.737: //3543925/DB88F73E9A2A/CCAPI/ccCallProceeding:
Jan 22 10:00:30.741: //3543925/DB88F73E9A2A/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=91, Params=0x2E88A5C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Jan 22 10:00:30.741: //3543925/DB88F73E9A2A/CCAPI/ccCheckClipClir:
   Destination Pattern=91T, Called Number=001669228XXXX, Digit Strip=FALSE
   Called Number=001669228XXXX(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=SIP  TEST
   Account Number=142442XXXX4, Final Destination Flag=TRUE,
   Guid=DB88F73E-3C34-11EA-9A2A-B8E4830712E5, Outgoing Dial-peer=91
Jan 22 10:00:30.741: //3543925/DB88F73E9A2A/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=001669228XXXX
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jan 22 10:00:30.741: //3543925/DB88F73E9A2A/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x13684C28, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=142442XXXX4,(Calling Name=SIP  TEST)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=001669228XXXX(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=91, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Jan 22 10:00:30.741: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 22 10:00:30.741: :cc_get_feature_vsa malloc success
Jan 22 10:00:30.741:  cc_get_feature_vsa count is 2
Jan 22 10:00:30.741: :FEATURE_VSA attributes are: feature_name:0,feature_time:373291192,feature_id:2380044
Jan 22 10:00:30.741: //3543926/DB88F73E9A2A/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Jan 22 10:00:30.741: //3543926/DB88F73E9A2A/CCAPI/ccCallSetContext:
   Context=0x2E88A0C
Jan 22 10:00:30.741: //3543925/DB88F73E9A2A/CCAPI/ccSaveDialpeerTag:
Jan 22 10:00:30.741: //3543926/DB88F73E9A2A/CCAPI/cc_api_call_proceeding:
   Interface=0x13684C28, Progress Indication=NULL(0)
SIP: (3543926) Group (a= group line) attribute, level 65535 instance 1 not found.
Jan 22 10:00:30.741: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 8.28.0.71:8115;branch=z9hG4bKaPjvpZq2iyf
From: "SIP  TEST" <sip:142442XXXX4@8.20.XX.YY:6055>;tag=bF1uQiuSRLMcK
To: <sip:911669228XXXX@8.28.0.71:8115>
Date: Wed, 22 Jan 2020 10:00:30 GMT
Call-ID: bUMBus4xMTUj
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Sent:
INVITE sip:001669228XXXX@121.244.230.10:5060 SIP/2.0
Via: SIP/2.0/UDP 10.196.236.238:5060;branch=z9hG4bK266A7D162
Remote-Party-ID: "SIP  TEST" <sip:142442XXXX4@10.196.236.238>;party=calling;screen=no;privacy=off
From: "SIP  TEST" <sip:142442XXXX4@10.196.236.238>;tag=423C4FD0-270B
To: <sip:001669228XXXX@121.244.230.10>
Call-ID: DB899366-3C3411EA-9A30B8E4-830712E5@10.196.236.238
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3683186494-1010045418-2586491108-2198278885
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1579687230
Contact: <sip:142442XXXX4@10.196.236.238:5060>
Expires: 180
Max-Forwards: 69
Session-Expires:  1893
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 302
v=0
o=CiscoSystemsSIP-GW-UserAgent 6755 2217 IN IP4 10.196.236.238
s=SIP Call
c=IN IP4 10.196.236.238
t=0 0
m=audio 28062 RTP/AVP 0 100 101
a=rtpmap:0 PCMU/8000
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
Jan 22 10:00:31.241: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Wed, 22 Jan 2020 10:00:31 GMT
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1579687231
Expires: 180
Max-Forwards: 69
Content-Length: 302
v=0
s=SIP Call
t=0 0
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
Jan 22 10:00:32.241: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Wed, 22 Jan 2020 10:00:32 GMT
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1579687232
Expires: 180
Max-Forwards: 69
Content-Length: 302
v=0
s=SIP Call
t=0 0
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
Jan 22 10:00:34.241: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Wed, 22 Jan 2020 10:00:34 GMT
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1579687234
Expires: 180
Max-Forwards: 69
Content-Length: 302
v=0
s=SIP Call
t=0 0
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
Jan 22 10:00:38.241: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Wed, 22 Jan 2020 10:00:38 GMT
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1579687238
Expires: 180
Max-Forwards: 69
Content-Length: 302
v=0
s=SIP Call
t=0 0
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
Jan 22 10:00:46.241: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Wed, 22 Jan 2020 10:00:46 GMT
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1579687246
Expires: 180
Max-Forwards: 69
Content-Length: 302
v=0
s=SIP Call
t=0 0
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
Jan 22 10:01:02.241: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Wed, 22 Jan 2020 10:01:02 GMT
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1579687262
Expires: 180
Max-Forwards: 69
Content-Length: 302
v=0
s=SIP Call
t=0 0
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
Jan 22 10:01:34.241: //3543926/DB88F73E9A2A/SIP/Error/act_sentinvite_wait_100: Out of retries
Jan 22 10:01:34.241: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG: No Inbound Container Created !!!
Jan 22 10:01:34.241: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931: No Inbound Container Created !!!
Jan 22 10:01:34.241: //3543926/DB88F73E9A2A/SIP/Error/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Invalid CCB/Data/Container
Jan 22 10:01:34.241: //3543926/DB88F73E9A2A/SIP/Error/sipAddSipContainerToCallEntry: Unable to add passthru hdrs
                          to container
Jan 22 10:01:34.241: //3543926/DB88F73E9A2A/CCAPI/cc_api_call_disconnected:
   Cause Value=102, Interface=0x13684C28, Call Id=3543926
   Call Entry(Responsed=TRUE, Cause Value=102, Retry Count=0)
Jan 22 10:01:34.241: //3543925/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Jan 22 10:01:34.241: //3543926/DB88F73E9A2A/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=3543926
Jan 22 10:01:34.241: //3543926/DB88F73E9A2A/CCAPI/ccCallDisconnect:
   Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=102)
   Cause Value=102, Call Entry(Responsed=TRUE, Cause Value=102)
Jan 22 10:01:34.241: //3543926/DB88F73E9A2A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x13684C28, Tag=0x0, Call Id=3543926,
Jan 22 10:01:34.241: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 22 10:01:34.241: :cc_free_feature_vsa freeing 163FF8B0
Jan 22 10:01:34.241:  vsacount in free is 1
Jan 22 10:01:34.241: //3543925/DB88F73E9A2A/CCAPI/ccCallDisconnect:
   Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Jan 22 10:01:34.241: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 408 Request Timeout
To: <sip:911669228XXXX@8.28.0.71:8115>;tag=423D47DC-4FF
Reason: Q.850;cause=102
Content-Length: 0
Jan 22 10:01:34.489: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname i bucket 16 c_hname Call-ID bucket 14
Jan 22 10:01:34.489: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname f bucket 13 c_hname From bucket 4
Jan 22 10:01:34.489: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname t bucket 8 c_hname To bucket 11
Jan 22 10:01:34.489: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname l bucket 0 c_hname Content-Length bucket 8
Jan 22 10:01:34.489: //-1/xxxxxxxxxxxx/SIP/Error/httpish_is_this_header_registered: hname v bucket 10 c_hname Via bucket 15
Jan 22 10:01:34.489: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
i: bUMBus4xMTUj
t: <sip:911669228XXXX@8.28.0.71:8115>;tag=423D47DC-4FF
CSeq: 1286749321 ACK
Max-Forwards: 70
l: 0
Jan 22 10:01:34.489: //3543925/DB88F73E9A2A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x13684C28, Tag=0x0, Call Id=3543925,
Jan 22 10:01:34.489: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 22 10:01:34.489: :cc_free_feature_vsa freeing 163FF990
Jan 22 10:01:34.493: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 22 10:01:34.493:  vsacount in free is 0
Jan 22 10:03:01.310: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:100@182.75.YY.XXX SIP/2.0
Via: SIP/2.0/UDP 5.196.198.36:5061;branch=z9hG4bK-2078770072;rport
Content-Length: 0
From: "sipvicious"<sip:100@1.1.1.1>;tag=6236346233336331313363340132393132343531383639
Accept: application/sdp
User-Agent: friendly-scanner
To: "sipvicious"<sip:100@1.1.1.1>
Contact: sip:100@5.196.198.36:5061
CSeq: 1 OPTIONS
Call-ID: 670827870465272336072838
Max-Forwards: 70
Jan 22 10:03:01.310: //3543927/35488BB59A31/SIP/Error/sipSPICheckReliableProvStringtag: Unable to access supported header values
Jan 22 10:03:01.310: //-1/xxxxxxxxxxxx/SIP/Error/rtpAvpCodec_to_voipCodec: Unexpected RTP PayloadType :255 in SDP Body
Sent:
SIP/2.0 200 OK
To: "sipvicious"<sip:100@1.1.1.1>;tag=423E9BF8-1984
Date: Wed, 22 Jan 2020 10:03:01 GMT
CSeq: 1 OPTIONS
Supported: 100rel,resource-priority,replaces,sdp-anat
Content-Length: 173
v=0
o=CiscoSystemsSIP-GW-UserAgent 1169 9025 IN IP4 10.196.236.238
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
TONY SMITH
I'm not seeing any reply to your outbound Invites.  The gateway tries seven times before giving up.  First thing I'd suggest is checking that your traffic is being sent sourced on the correct interface.  If it's not then the service provider either won't recognise your gateway, or won't be able to reply as the IP address would be meaningless.   Is there a firewall between your gateway and the ITSP?
No Tony, There are no firewalls In between. I will check the traffic source and confirm.
