Showing results forĀ
Search instead forĀ
Did you mean:Ā
Voice mail pilot number in CME/CUE getting busy signal
owaisqadri
Hi all,
I am facing problem in CME/CUE vocie mail pilot number when pressing the mesage button on  ip phone or when i dial the pilot number of vocie mail it giving busy signal. please advice for the same. it seemd licences issue or some thing else lic details are mentioned below.
GWSARICUE002# sh license all
License Store: Primary License Storage
StoreIndex:  0  Feature: VMIVR-VM-MBX                      Version: 1.0
        License Type: Permanent
        License State: Active, In Use
        License Count: 55 /55
        License Priority: Medium
License Store: Evaluation License Storage
        License Type: Evaluation
        License State: Inactive
            Evaluation total period:  8 weeks  4 days
            Evaluation period left:  8 weeks  3 days
        License Count: 600 / 0
        License Priority: Low
StoreIndex:  1  Feature: VMIVR-PORT                        Version: 1.0
        License State: Active, Not in Use, EULA accepted
            Evaluation period left:  0 minute   0 second
        License Count: 60 / 0
StoreIndex:  2  Feature: VMIVR-IVR-SESS                    Version: 1.0
13 Replies 13
paolo bevilacqua
If you have configured more mailbox than licenses, voicemail will stop working. You can see that with show voicemail mailbox.
Either reduce mailboxes, or add licenses.
Dear paolo,
Please  find  the show vociemail mailboxes details. usagae was 55/55. please advice
VGWSARICUE002# show voicemail mailboxes
OWNER               MSGS NEW SAVE DEL BCST FUTR FAX MSGTIME   MBXSIZE  USED
"AMSY"              5    5   0    0   0    0    0   967       3927     25 %
"AESM"              0    0   0    0   0    0    0   0         3927     0 %
"AAGM"              0    0   0    0   0    0    0   0         3927     0 %
"ZAG"               1    1   0    0   0    0    0   241       3927     6 %
"TUAJ"              3    3   0    0   0    0    0   482       3927     12 %
"AHHH"              0    0   0    0   0    0    0   0         3927     0 %
"MOFF"              7    7   0    0   0    0    0   1003      3927     26 %
"PAAM"              0    0   0    0   0    0    0   0         3927     0 %
"HAZE"              2    2   0    0   0    0    0   6         3927     1 %
"WABD"              1    1   0    0   0    0    0   241       3927     6 %
"GAEL"              12   12  0    0   0    0    0   2406      3927     61 %
"HTHA"              0    0   0    0   0    0    0   8         3927     1 %
"MGHZ"              0    0   0    0   0    0    0   0         3927     0 %
"KGE"               0    0   0    0   0    0    0   0         3927     0 %
"HR"                3    3   0    0   0    0    0   487       3927     12 %
"AYHA"              11   11  0    0   0    0    0   2641      3927     67 %
"KDAA"              1    1   0    0   0    0    0   241       3927     6 %
"SZMJ"              0    0   0    0   0    0    0   0         3927     0 %
"HOSD"              6    6   0    0   0    0    0   273       3927     7 %
"SYAX"              1    1   0    0   0    0    0   6         3927     1 %
"HMRE"              21   21  0    0   0    0    0   3859      3927     98 %
"AFUA"              1    1   0    0   0    0    0   241       3927     6 %
"MALL"              0    0   0    0   0    0    0   0         3927     0 %
"MEDH"              0    0   0    0   0    0    0   0         3927     0 %
"AAKH"              0    0   0    0   0    0    0   0        3927     0 %
"HMSF"              0    0   0    0   0    0    0   0         3927     0 %
"MFAE"              0    0   0    0   0    0    0   0         3927     0 %
"SADK"              0    0   0    0   0    0    0   0         3927     0 %
"WLMA"              0    0   0    0   0    0    0   0         3927     0 %
"TAQS"              0    0   0    0   0    0    0   0         3927     0 %
"ASAI"              2    1   1    0   0    0    0   481       3927     12 %
"KMMT"              0    0   0    0   0    0    0   0         3927     0 %
"HDAT"              0    0   0    0   0    0    0   0         3927     0 %
"KKAV"              2    2   0    0   0    0    0   270       3927     7 %
"WMAN"              0    0   0    0   0    0    0   0        3927     0 %
"MANR"              0    0   0    0   0    0    0   0         3927     0 %
VGWSARICUE002#
Dear David Hailey,
Can you help me in this regard...
It would be prudent to first grab output of 'debug ccsip mess' and 'debug voip ccapi inout' off CME during a failure, to see who is disconnecting and why.  It may not be a license issue.
Thanks Steven Holl for the inputs i will capture all the required debug & will sahre with you asap.
b ut i have alreday capture some ccsip message debug please have a look .
voice mail pilot number is 998.
May  7 10:43:01.531: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:998@10.45.143.253:5060 SIP/2.0
Via: SIP/2.0/UDP 10.45.143.254:5060;branch=z9hG4bK520210F4
To: <998>;tag=ds9af6c06
Date: Sat, 07 May 2011 10:43:01 GMT
Call-ID: 9D78842A-77CD11E0-8E54EF32-E12AB321@10.45.143.254
Max-Forwards: 70
CSeq: 101 ACK
Allow-Events: telephone-event
Content-Length: 0
I need more than just a snip of a single message for an analysis.  A single ACK isn't sufficient to look at a SIP call failure.
You should see something close to this for a SIP call:
It's likely worth you time to familiarize youself with what the basic SIP call flows look like:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_ipphon/sip7960/sadmin31/bsipcflw.htm#1013217
steven holl.
I am captured all the debugs as requested for voice mail pilot number 998  & Ip phone ext numbber is 337 all debug log are atatched with this
Debugs show the issue is on CUE--it is returning a 486 Busy.Direct troubleshooting to CUE.  Can you dial an AA on the CUE properly?
May 14 07:22:48.987: //47969/CD99C2B5B0E9/SIP/Msg/ccsipDisplayMsg:
Received:
--More--         SIP/2.0 486 Busy Here
Via: SIP/2.0/UDP 10.45.143.254:5060;branch=z9hG4bK52A0152F
To: <998>;tag=dsd5a1c5b0
Call-ID: CE07042A-7D3111E0-B0EEEF32-E12AB321@10.45.143.254
CSeq: 101 INVITE
Content-Length: 0
Allow: INVITE, BYE, CANCEL, ACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: CE07042A-7D3111E0-B0EEEF32-E12AB321@10.45.143.254
hi steven,
AA is working fine  i am tried that we 999 as AA number. what next to trouble shoot
- Did AA successfully transfer calls to the extension? Have you tried the following?
- remove newly added mailboxes  then test
- Reload the CUE
Can you post here your CUE and CME configuration?
-Paul
dear paul,
AA is also not  workign now giving busy signal while dailing the AA number. i am attaching CME & CUE configuration & debug of both voice mail pilot number & AA
vocie mail polit number 998
AA number 999
Any body can help me on this issue,,,
Why don't you engage a professional UC engineer.
He can connect remotely and resolve all your issues easily.
