05-14-2013 11:00 PM - edited 03-16-2019 05:19 PM
Dear All,
I am very new in Cisco Voice world, So I wish to prepare a lab for Multisite Distributed Call processing(Two independent CUCM in two Site).
For this lab do we need Voice gateway for this, if its need what are the configuration we need.
Please give me steps for this lab.
I will be really helpful.
05-14-2013 11:47 PM
Hi Jinoy.
To manage call processing between to indipendent cluster, a SIP trunk between them is enough.
You will need a Voice gateway (one per site) if you want to connect your clusters to the PSTN or to a SIP provider and , in this case, a voice gateway with CUBE functionality is highly recommended.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
05-14-2013 11:57 PM
Hi Carlo,
Thank you for good response, throguh PSTN is fine,
As a lab I wish to do this task throguh WAN link only. So I beilive we need to use VoIP Peer...
Will you please give me the steps or good link for MultiSite distributed setup through WAN link.
05-15-2013 06:15 AM
As answered properly by Carlo (+5) you do not need any dial-peers on a gw to have 2 CUCM clusters talk to each other, either build a SIP trunk on each side to point to the other or Intercluster trunk (if CUCM is older than 8.X). Then build Route Patterns pointing to the SIP trunks via preferably Route List --> Route Group --> SIP trunk.
HTH,
Chris
