Voice Pri crackling
jgranda
Cisco 2821 with dual Vwic T1 card
Having a probkem with two PRI circuit the voice crakling. Both circuit are running error free. Do the following
1) replace the Dual Vwic card same issue
2) Replaced three DSP cards
3) change the slot from 1 to 3
All internal calls no issues. Only calls that are coming through the both PRI get the crakling. The phone company has tested the circuit ans is poing to the equipment. Can I get any recomendation what to test next.
Jose
16 Replies 16
Hi Jose,
Can you please post the show run of your gateway and specify the IOS version?
Is the gateway on the same subnet of CUCM or is behind a firewall?
Can you reproduce a bad call and issue the show voice call status on gateway?
Carlo
Please rate all helpful posts "The more you help the more you learn"
ppitts
We're you able to find out what the problem was?
