Voice router clarification
adamgibs7
Level 6
Level 6
Below is the BOQ for voice router,
presales ordered 2 no's of CME router and 9'nos of routers with 25 seats SRST license, How i wll sortout them physically by which command i will come to know that this 2 no's are for CME purpose and the others are SRST.
#Part NumberPart DescriptionService DurationQuantity Part NumberPart DescriptionService DurationQuantity
 C2921-CME-SRST/K92921 Voice Bundle w/PVDM3-32,FL-CME-SRST-25,UC Lic,FL-CUBE10-9 C2921-CME-SRST/K92921 Voice Bundle w/PVDM3-32,FL-CME-SRST-25,UC Lic,FL-CUBE10-2
 CON-PSRT-2921CMSTPRTNR SS 8X5XNBD 2921 Voice Bundle w/ UC License PAK12.003 CON-PSRT-2921CMSTPRTNR SS 8X5XNBD 2921 Voice Bundle w/ UC License PAK12.002
 S29UK9-15204MCisco 2901-2921 IOS UNIVERSAL-3 S29UK9-15204MCisco 2901-2921 IOS UNIVERSAL-2
 FL-SRSTCisco Survivable Remote Site Telephony License-3 FL-SRSTCisco Survivable Remote Site Telephony License-2
 FL-CME-SRST-25Communication Manager Express or SRST - 25 seat license-6 FL-CME-SRST-25Communication Manager Express or SRST - 25 seat license-4
 SM-SRE-710-K9SRE 710 (4GB MEM,500GB 7K HDD,1C CPU) for router bundle-3 SM-SRE-710-K9SRE 710 (4GB MEM,500GB 7K HDD,1C CPU) for router bundle-2
 CON-PSUU-SMSRE710PRTNR SUP SW UPG Svcs Ready Engine 710 (4GB MEM,500GB 7K)12.003 CON-PSUU-SMSRE710PRTNR SUP SW UPG Svcs Ready Engine 710 (4GB MEM,500GB 7K)12.002
 SCUE-SM-8.6-K9Cisco Unity Express Release 8.6-3 SCUE-SM-8.6-K9Cisco Unity Express Release 8.6-2
 FL-CUE-NR-PORT-2Unity Express License - Non Re-hostable - 2 Port-6 FL-CUE-PORT-2Unity Express License - 2 Port-2
 CUE-LANG-ARACisco Unity Express - Saudi Arabian Arabic-3 FL-CUE-NR-PORT-2Unity Express License - Non Re-hostable - 2 Port-4
 CUE-LANG-ENGCisco Unity Express - British English-3 CUE-LANG-ARACisco Unity Express - Saudi Arabian Arabic-2
 SM-HDD-SATA-500GB500 GB hard disk drive for SRE 710 and 910-3 CUE-LANG-ENGCisco Unity Express - British English-2
 SM-MEM-VLP-2GB2GB very low profile SDRAM for SRE service modules-6 SM-HDD-SATA-500GB500 GB hard disk drive for SRE 710 and 910-2
 VWIC3-1MFT-T1/E11-Port 3rd Gen Multiflex Trunk Voice/WAN Int. Card - T1/E1-3 SM-MEM-VLP-2GB2GB very low profile SDRAM for SRE service modules-4
 PWR-2921-51-ACCisco 2921/2951 AC Power Supply-3 VWIC3-1MFT-T1/E11-Port 3rd Gen Multiflex Trunk Voice/WAN Int. Card - T1/E1-2
 CAB-ACUAC Power Cord (UK), C13, BS 1363, 2.5m-3 PWR-2921-51-ACCisco 2921/2951 AC Power Supply-2
 CAB-E1-RJ45BNCE1 Cable RJ45 to Dual BNC (Unbalanced)-3 CAB-ACUAC Power Cord (UK), C13, BS 1363, 2.5m-2
 FL-CME-SRST-25Communication Manager Express or SRST - 25 seat license-3 CAB-E1-RJ45BNCE1 Cable RJ45 to Dual BNC (Unbalanced)-2
 FL-CUBEE-5Unified Border Element Enterprise License - 5 sessions-6 FL-CME-SRST-25Communication Manager Express or SRST - 25 seat license-2
 PI-MSE-PRMO-INSRTInsert, Packout - PI-MSE-3 FL-CUBEE-5Unified Border Element Enterprise License - 5 sessions-4
 SL-29-IPB-K9IP Base License  for Cisco 2901-2951-3 PI-MSE-PRMO-INSRTInsert, Packout - PI-MSE-2
 SL-29-UC-K9Unified Communication  License  for Cisco 2901-2951-3 SL-29-IPB-K9IP Base License  for Cisco 2901-2951-2
 HWIC-BLANKBlank faceplate for HWIC slot on Cisco ISR-9 SL-29-UC-K9Unified Communication  License  for Cisco 2901-2951-2
 ISR-CCP-EXPCisco Config Pro Express on Router Flash-3 HWIC-BLANKBlank faceplate for HWIC slot on Cisco ISR-6
 MEM-2900-512MB-DEF512MB DRAM for Cisco 2901-2921 ISR (Default)-3 ISR-CCP-EXPCisco Config Pro Express on Router Flash-2
 MEM-CF-256MB256MB Compact Flash for Cisco 1900, 2900, 3900 ISR-3 MEM-2900-512MB-DEF512MB DRAM for Cisco 2901-2921 ISR (Default)-2
 PVDM3-3232-channel high-density voice and video DSP module-3 MEM-CF-256MB256MB Compact Flash for Cisco 1900, 2900, 3900 ISR-2
 SM-D-BLANKBlank faceplate for DW slot on Cisco 2951 and 3925-3 PVDM3-3232-channel high-density voice and video DSP module-2
 FL-CUE-PORT-2Unity Express License - 2 Port-3 SM-D-BLANKBlank faceplate for DW slot on Cisco 2951 and 3925-2
thanks
5 Replies 5
Aaron Harrison
The license are honour-based, so just keep track of what you are using where however you see fit. They aren't really 'attached' to any specific router in any way, i.e. you don't register them or input license codes.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Dear Aaron, sreekanth
i didn't understood the replies, but what i am assuming all routers have same licenses and any router can be mounted anywhere.
Attached is the licenses command output from one of the srst enabled router when i enable by command call-manager-fallback and the other is from CME, please have a look and suggest.
thanks
The routers do not enforce licensing.
You CAN use SRST or CME on any or all the routers, but if you do so you are breaking the terms of the licensing.
You have purchased 2 CME licenses, so you SHOULD use CME on ONLY two routers.
For SRST, you have 9 licenses, so use those on a max of ONLY 9 routers.
Does that make it clearer?
Aaron
Dear Aaron,
How did you identified that the license are honour-based, can you share with me,
Sreekanth Narayanan
I see that the orders are for ISR G2 routers. On these you do not need to install the license. The licenses are honor based. You must have them in case of audits. The number of phones that can fall back to SRST is based only on the platform.
