First of all check the call flow of the incoming call ,list out the Dial Peer ,translation rules ,Translation pattern directory numbers, etc
Then I would suggest to trace the failed call on the CDR. It will give you the clue about that call details ,Cause codes,Call identifier etc. Then you may check traces.
Safdar,
Please rate if it helps.
Best wishes,
Safdar
