VOIP CS5 traffic in default queue ?
markhayek
THere are reports of poor audio at this site on Polycom VOIP phone.
QOS appears to be setup correctly using LLQ.
When I look at the service-policy output on serial, it seems to indicate there is CS5 traffic in the default-queue, but nearly no packets in the VOIP que.  Look at this output, is it true  that packets marked CS5 are showing upo in default que ?
Serial0/0/0:0
  Service-policy output: QOS-EDGE
    queue stats for all priority classes:
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 370/53194
        Class-map: VOICE-TP (match-any)
      370 packets, 53194 bytes
      5 minute offered rate 0000 bps, drop rate 0000 bps
      Match: ip dscp ef (46)
        5 minute rate 0 bps
      Match: ip dscp cs4 (32)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Priority: 45% (691 kbps), burst bytes 17250, b/w exceed drops: 0
    Class-map: VOICE-CONTROL (match-any)
      71920 packets, 60413494 bytes
      5 minute offered rate 1000 bps, drop rate 0000 bps
      Match: ip dscp af31 (26)
        42 packets, 4664 bytes
        5 minute rate 0 bps
      Match: ip dscp cs3 (24)
        71878 packets, 60408830 bytes
        5 minute rate 1000 bps
      Queueing
      (pkts output/bytes output) 71920/60413494
      bandwidth 5% (76 kbps)
    Class-map: class-default (match-any)
      7952723 packets, 1506140475 bytes
      5 minute offered rate 117000 bps, drop rate 0000 bps
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops/flowdrops) 0/493/0/0
      (pkts output/bytes output) 7987939/1522050104
      Fair-queue: per-flow queue limit 16 packets
        Exp-weight-constant: 9 (1/512)
        Mean queue depth: 0 packets
        dscp       Transmitted      Random drop      Tail/Flow drop Minimum Maximum Mark
                    pkts/bytes       pkts/bytes      pkts/bytes   thresh  thresh  prob
        default  6144806/1139948538    459/392582        33/1452              20            40  1/10
        af11         456/58621           0/0              0/0                 32            40  1/10
        af21         129/16376           0/0              0/0                 32            40  1/10
        cs3            5/4279            0/0              0/0                 26            40  1/10
        cs5      1466810/298599872       0/0              0/0                 30            40  1/10 <--   WHY is CS5 traffic here ?
        cs6       375897/83461746        1/112            0/0                 32            40  1/10
QOS
class-map match-any VOICE-CONTROL
 match ip dscp af31
 match ip dscp cs3
class-map match-any VIDEO-CONFERENCE
 match ip dscp af41
class-map match-any VOICE-TP
 match ip dscp ef
 match ip dscp cs4
policy-map QOS-EDGE
 class VIDEO-CONFERENCE
  bandwidth percent 10
 class VOICE-TP
  priority percent 45
 class VOICE-CONTROL
  bandwidth percent 5
 class class-default
  fair-queue
  random-detect dscp-based
interface Serial0/0/0:0
 description T1 to RTFLWNTCD01-S3-1-1-19:1
 ip address 10.192.55.250 255.255.255.252
 ip pim sparse-dense-mode
 service-policy output QOS-EDGE
Is this becuase the 3500 switch doesnt have a COS-DSCP map setup for COS5 = DSCP=46 ?
router:
 Cos-dscp map:
        cos:   0  1  2  3  4  5  6  7
       dscp:   0  8 16 26 32 46 48 56
switch 3560:
Cos-dscp map:
       dscp:   0  8 16 24 32 40 48 56
yahsiel2004
Level 7
Level 7
Are you marking your VoIP traffic with CS5? If that's the case change it back to EF and or match on CS5 on your "VOICE-TP" class-map.
Yosh
HTH Regards, Yosh
Are you sure that your polycom phone is marking the rtp stream as EF/CoS5. In this case, you need to configure QoS trust on your switch on make sure that you are delivering the marking to router.
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos
interface ***phones/router_facing_interfaces***
 mls qos trust dscp
