08-13-2018 07:44 AM - edited 03-17-2019 01:20 PM
I am trying to achieve the following... I want all the call that cames in my gateway (PRI) to send all the call to the call manager. Is there a way I can use a wildcard to say... "all incoming calls . go to session target: call manager IP..."
My question is related to the wildcard. I want all the calls to be trapped and then to be sent to the 4 Call Managers we have with a priority 1,2,3,4.
Can I use something like this:
dial-peer voice 1 voip
preference 1
answer-address .T
progress_ind setup enable 3
voice-class codec 1
voice-class h323 1
session target ipv4:1.1.1.1
dtmf-relay h245-alphanumeric
ip precedence 5
no vad
Many Thanks
Lilieli
08-14-2018 01:00 AM
08-14-2018 05:25 AM
08-14-2018 05:40 AM
yes that would work, you have an incoming dialpeer and an outgoing dial peer.
remember to out called number translations on the cucm gateway that carries the incoming calls if you use for instance 5 digit internal extensions
