voip1
nettuno8_20111
hi my name is sorrento ciro I have a router 2011xm I have 4 voip that communicate with each other internally I would like some help to make the voip communicate even outside the local network such as urban calls and vice versa to receive local calls someone could help me? the output interface would be f0 / 0 configured as a dialer thanks.
Jaime Valencia
You need some way to communicate with the PSTN, FXO, PRI, BRI or a SIP trunk, do you have any of those?
java
if this helps, please rate
