Warning! DSPs 1 in slot 0 are using non-default firmware from device flash:
Im having a problem on my 2801 router, my fxo and fxs port are not fucntioning, when i check the dsp it shows below; i have tried different ios still the same problems encountered.
rtr01#show voice dsp detailed
edsp 0001 01 g729r8 p  0.1 IDLE  50/0/1.1
edsp 0002 01 g729r8 p  0.1 IDLE  50/0/5.1
edsp 0003 01 g729r8 p  0.1 IDLE  50/0/6.1
This is not recommended, the IOS default version is 24.3.0
----------------------------FLEX VOICE CARD 0 ------------------------------
                           *DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND     : (bad)bad    (shut)shutdown  (dpend)download pending
DSP   DSP                 DSPWARE CURR  BOOT                         PAK   TX/RX
TYPE  NUM CH CODEC        VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
C5510 001 01 None           0.0.0 bad   idle      0  0                 0          0/0
C5510 001 02 None           0.0.0 bad   idle      0  0                 0          0/0
C5510 001 03 None           0.0.0 bad   idle      0  0                 0          0/0
C5510 001 04 None           0.0.0 bad   idle      0  0                 0          0/0
C5510 001 05 None           0.0.0 bad   idle      0  0                 0          0/0
C5510 001 06 None           0.0.0 bad   idle      0  0                 0          0/0
C5510 001 07 None           0.0.0 bad   idle      0  0                 0          0/0
C5510 001 08 None           0.0.0 bad   idle      0  0                 0          0/0
                           *DSP SIGNALING CHANNELS*
C5510 001 01 {flex}         0.0.0 free  idle      0  0 0/0/0           0          0/0
C5510 001 02 {flex}         0.0.0 free  idle      0  0 0/0/1           0          0/0
C5510 001 03 {flex}         0.0.0 free  idle      0  0 0/2/0           0          0/0
C5510 001 04 {flex}         0.0.0 free  idle      0  0 0/2/1           0          0/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
#sho voice port summary
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/0           --  fxs-ls      up    dorm on-hook  idle     y
0/0/1           --  fxs-ls      up    dorm on-hook  idle     y
0/2/0           --  fxo-ls      up    dorm idle     on-hook  y
0/2/1           --  fxo-ls      up    dorm idle     on-hook  y
50/0/1          1      efxs     up    up   on-hook  idle     y
50/0/5          1      efxs     up    up   on-hook  idle     y
50/0/6          1      efxs     up    dorm on-hook  idle     y
PWR FAILOVER PORT        PSTN FAILOVER PORT
can somenone help to advice. th
nitsinha
Level 4
Level 4
I see that the DSPware version says 0.0.0 and the current state shows "BAD" which should not be the case. Are you running 12.4(24)T IOS because i see that the default version of DSP should be 24.3.0 as printed in the output. By default the IOS itself contains the default DSPware in it but if it does not show up in your router, try reloading the router to see whether it fixes your issue. If not check the following link which lists the steps to be followed to install a new DSPware on your router.
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a0080a7af82.shtml
Hope that helps
Nitesh
PS:pl rate helpful posts
hI Nitesh,
yes im using 12.4(24)T ios i also tried 12.4(22)T and 12.4(22)YB, i hanve the same problem.  do you have the dsp firmware
dsp_c5510_flex.rbf? the problem is i dont have active support from cisco so i cant log a case to them.
thanks,
marlon
alsarinetworks
Hi Marlon
I upgraded the IOS of my router 2801 (as gateway) to 12.4(24)T8. When I restarted the router I watched this message:
voice-card 0
 ! Warning! DSPs 5 in slot 0 are using non-default firmware from device flash:
 ! This is not recommended, the IOS default version is 24.3.8
Then, configuring the router I activated the dspfarm because I was using two dsp cards, and after restart the router the message disappeared.
The firmware for dsp is in the IOS, when you restart this problem will be fixed.
