04-16-2010 02:33 PM - edited 03-15-2019 10:19 PM
Hi all,
Who has a good tool/software for doing webdial through TAPI on a CUCME.
E.g. clicking on a link like callto://+4xxxxxxxxxx, the number 004xxxxxxxxxx should be dialed
through TAPI.
Any ideas?
Norbert
04-16-2010 05:24 PM
Try Cisco Unified Call Connector.
Hope to help, if it does please rate.
Best regards,
-- Adrián.
04-18-2010 02:24 AM
it depends on what you want to do exactly.
your phone can also dial with uri feature over http.
so you could click a link to send the phone xml command to dial.
in that case your website has to be personalized - every user gets links to his own phone ip address
you would need a webserver and a website for your contacts.
or a form to dial the number.
uri freature is very simple and does not require any other software but a webserver.
lg
Arnulf
