What are the feature and programming differences between CUCM 7 to CUCM 10.5?
Taylor Scott
Anas Abueideh
Level 9
Level 9
there is a lot of difference between CUCM 7 and CUCM 10.5
CUCM 10.5 main features
-only supported over vmware
-new licensing model , user based license instead of DLU
-new phones support
-Free Jabber Messaging
-Queue Support in Hunt pilot
-Rich SIP support
-ILS/GDPR
-Self provisioning
-Attendant Console on different Server.
-Rich video support
Anas
don't forget to rate the helpful posts
Jaime Valencia
If you want to find out every single thing that is different, you would need to go thru the RNs and new and changed doc for all versions between your version and CUCM 10.5.
java
if this helps, please rate
