11-17-2015 06:21 AM - edited 03-17-2019 04:55 AM
Team,
Can any one brief it in a simple sentence
TCS ,OLC and MSD in H.245!
11-17-2015 06:43 AM
TCS terminal capability set - which lists capabilities supported (codecs & dtmf methods). Both endpoints provides the capabilities they support for the call
OLC open logical channel - which asks the endpoint to open a port for media communication
Endpoint responds with a OLC ACK message providing the RTP port number it has opened for communication for that call
MSD is master slave determination between the endpoints
Rajan
Please rate useful posts
11-17-2015 06:47 AM
Rajan thanks for your reply,
In TCS,What is capabilites meant ?
MSD, On what basis this is determined
Codec and Ip address negotation, Are these comes under TCS?
I am new to this. Please consider, though it is quite old
11-17-2015 06:56 AM
Capabilties includes codecs and dtmf methods not IP address
MSD is explained well in the below discussion:
https://supportforums.cisco.com/discussion/12206826/master-slave-determination-cucm
http://tools.ietf.org/html/draft-rfced-info-lantz-00
11-17-2015 07:00 AM
Below link shows how the call flow looks like:
http://docwiki.cisco.com/wiki/Cisco_IOS_Voice_Troubleshooting_and_Monitoring_--_H.323-Related_Standards
Rajan
11-17-2015 07:59 PM
Hi Manzoor,
In addition to the nice info provided by Rajan you may check the following doc which shows how to track H225 and H245 messages in a callmanager trace and how these messages look like
https://supportforums.cisco.com/document/44911/tracking-h323-calls-cucm-sdi-traces#Find_the_Negotiated_H.245_Port
Manish
- Do rate helpful posts -
