what is the best and recommended/easy/flexible method to register around 150 IP phones to CUCM
Ibrahim Jamil
Level 6
Level 6
Hi Freinds
what is the best and recommended/easy/flexible  method to register around 150 IP phones to CUCM 11.5 ,
Georgios Fotiadis
The best way would be to use the Bulk Admin Tool (BAT). You practically create an Excel document that contains the MAC/DNs etc, so as to massively create the configuration at CUCM for all 150 IP Phones.
More info here: Cisco Unified Communications Manager Bulk Administration Guide
Georgios
Please rate if you find this helpful.
Self provisioning is also an option
java
if this helps, please rate
thanks freinds
