06-26-2020 11:44 PM
Hi Guys,
What is the best solution from Cisco for these requirements :
Analogue Extensions - Up To 200 Extension
IP Extensions - Up To 200 Extension
Mobile Extensions - Up To 200 Extension
Trunk Line - 100 Lines, Interfaces (Media Gateway) Lan/Wan 2
Fast Ethernet
Can I use ATA analog to IP converter for the 200 Analog phones? or Is there any solution from Cisco?
and what is the Gateway which can handle 100 Trunk Lines?
Thanks for all
06-27-2020 06:26 AM
I suggest you reach out to a Cisco partner with voice specializations to discuss this, they can advise what you can use for this scenario.
06-27-2020 09:06 AM
Agree, and the partner will need to know more about your requirements like what level of functionality is needed, and how the analogue phones are cabled. I see you use the UK spelling for analogue. This isn't a North Sea installation is it?
06-27-2020 09:23 PM
Thanks for all guys.
