What is the CSS in Translation Pattern used for
yuhuiyao
All,
what is the CSS in Translation Pattern used for? Can I leave it blank? To my understanding there will be no need for a translated number to initiate a call.
Thanks.
Jaime Valencia
That CSS defines what DNs you can reach after the translation is applied.
If the DN you're translating the original number to is not within that CSS the call will fail.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
