What means the asterisk before a directory number?
I have seen that several times at my actual job
Directory Number
Directory Number* Shared Line
Partition
Directory Number Settings
Voice Mail Profile
(Choose <None> to use default)
Calling Search Space
User Hold Audio Source
Network Hold Audio Source
Auto Answer
Thanks in advance
Cesar
phooghen
The asterisk Character has no special meaning.
It's just a dialable character.
Directory number:
Enter a dialable phone number. Values can include route pattern  wildcards and numeric characters (0 through 9). Special characters such  as a question mark (?), exclamation mark (!), backslash (\), brackets  ([ ]), plus sign (+), dash (-), asterisk (*), caret (^), pound sign (#),  and an X are also allowable. Special characters that are not allowed  are a period (.), at sign (@), dollar sign ($), and percent sign (%).
At the beginning of the pattern, enter \+ if you want to use the  international escape character +. For this field, \+ does not represent a  wildcard; instead, entering \+ represents a dialable digit.
Note     : When a pattern is used as a directory number,  the display on the phone and the caller ID that displays on the dialed  phone will both contain characters other than digits. To avoid this,  Cisco recommends that you provide a value for Display (Internal Caller  ID), Line text label, and External phone number mask.
The directory number that you enter can appear in more than one partition.
If you configure this field under Call Routing > Directory Number,  you can enter insert directory numbers in bulk by entering a range (that  is, by entering the beginning directory number in the first field and  by entering the ending directory number in the second field); by using  this method, you can create up to 500 directory numbers at a time.
phooghen
Directory number:
Well said phooghen. Moreover, we use this asterisk to dial a Voice Mail no. directly. For the time being, if you have got 4digits ext. used in your cluster and want to get into VM box without ringing the phones, we can use this pattern *XXXX and set the CF All to VM.
In this case i didnt figured out why its being used, because this is a call park extension, but in some other cases i understand why, because, this is a large network, and if we want to dial extensions outside the coutry, we must dial "5" first.
thanks to both of you
Cesar
