Showing results forĀ
Search instead forĀ
Did you mean:Ā
when dial the pstn number it's not taking the 3rd PRI
Lalesh Kabade
Hi all,
currently i am using three reliance, using h.323 gateway
so my requirement is want to give only 3rd pri acess to the specific user
for that i create
on gateway
0/1/1 - this is only one pri that ISD allowd
dial peer voice 1 pots
destination pattern  900T
prefix digits 00
port 0/1/1
one partition and one css and in that css i assign the partition which is created now, and the same css assigned to the specificed user.
route pattern created 1 for 9T allow the pattern
one dial peer
dial peer 1 pots
destina 900T
prefix digits 00
port 0/1/1
but after doing this it not taking the 3rd pri
can someboday assist me how would i give the only 3rd pri access to the specific user.
Lalesh.
paolo bevilacqua
