Which 1800 series router
ZCostello
I am setting up a voice lab and need a Cisco router to complete the set up. I am looking at the 1800 series but unsure of what is best. I have Call Manager 6.0 running on a separate server. I need to add a gateway to the network so I can send offnet calls to my service provider. I would like to use the Cisco router as an h323 gateway that connects to a low cost sip provider.
Topology:
Call Manager -SCCP- h323 gateway -SIP- service provider
Router needs to:
Support 15 phones
QOS
Dial peers
Sip authentication with the sip provider
Connect to call manager via SCCP
Any insight would be appreciated!
sadbulali
Level 4
Level 4
Cisco 1800 Fixed-Configuration Integrated Services Routers are the next evolution of the award-winning Cisco 1700 Series access routers. The Cisco 1800 Series fixed-configuration routers are designed for secured broadband access, Metro Ethernet, and wireless connectivity. Cisco 1801 integrated router with fixed configuration supports voice as it comes with Cisco IOS IP Broadband feature set.It requires Cisco IOS version 12.4T.The CISCO 1801 is an ADSL over POTS router with 8-port 10/100BASE-T switch, ISDN S/T backup, Cisco IOS IP broadband, 32 MB Flash, and 128 MB DRAM.
