02-27-2009 07:02 AM - 편집 03-15-2019 04:30 PM
Does anyone know if the 7940 supports whisper intercom? I have it working to our 7961 phones, but the intercom button does not show up on the 7940's second line. It does show in the GUI for CME, just not on the phone.
Seth
날짜: 02-27-2009 07:23 AM
yes, make sure you're not running into a restriction:
SCCP: Configuring Whisper Intercom
To enable the Whisper Intercom feature on a directory number, perform the following steps.
Prerequisites
â¢Cisco Unified CME 7.1 or a later version.
â¢IP phones require SCCP 12.0 or a later version.
Restrictions
â¢Not supported on single-line phone models such as the Cisco Unified IP Phone 7906 or 7911.
â¢Whisper intercom directory numbers can place calls only to other whisper intercom numbers.
â¢A directory number can be configured as either a regular intercom or a whisper intercom, not both.
â¢Dual-line and octo-line directory numbers are not supported as intercom lines.
â¢Only one intercom call, either incoming or outgoing, is allowed on the phone at one time.
â¢Call features are not supported on intercom calls.
java
if this helps, please rate
날짜: 02-27-2009 08:11 AM
You'll need to make sure your 7940 is on SCCP version 12.
You can determine this version with 'show ephone register':
ephone-1[0] Mac:0019.E803.5B1A TCP socket:[3] activeLine:0 REGISTERED in SCCP ver 12/9
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:8
IP:14.50.233.6 49229 7971 keepalive 51365 max_line 8
button 1: dn 1 number 11*11 CH1 IDLE CH2 IDLE
Preferred Codec: g711ulaw
What you're interested in is this: SCCP ver 12/9, where 12 is the active version. 9 is another number that's not relevant here.
-nick
날짜: 02-27-2009 08:51 AM
Well, that is the problem. The output shows SCCP version 11/9.
Now the questions is, how to upgrade that? I am running CME 7.1 and used the latest files for the phones.
The load I have is P00308000500.loads and I have that listed in the telephone-services section for the 7960-7940. I also have all three files for that load listed in the TFTP-server config on the router.
The phone shows that code is in use on it.
Seth
날짜: 02-27-2009 11:15 AM
Hi Seth,
There's really only one option - download the most recent firmware and try it. You're probably pretty close with that firmware, but it's worth a look.
Otherwise, you may not be able to whisper on 7940/60s.
hth,
nick
날짜: 02-27-2009 11:59 AM
I did download the latest file in order to get the 7.1 CME.
So if there is a new version of code that I am missing, can someone tell me how to get it?
Seth
날짜: 02-27-2009 01:12 PM
Hi Seth,
There's a good chance this isn't a feature that will be supported on the 7940s and 60s right now. It might be later, but new feature support on those phones are very limited.
-nick
새로운 아이디어를 발견하고 저장하세요. 전문가 답변, 단계별 가이드, 최근 주제 등 다양한 내용을 확인해 보세요.
처음이신가요? 아래 팁들을 확인해 보세요. 시스코 커뮤니티 사용하기 새 멤버 가이드
