03-30-2015 04:01 AM - edited 03-17-2019 02:29 AM
I know that QSIG has been designed specially for multi-vendor PBXs Supplementary Service inter-operation.
But it seems to me that PRI E1/TI can also do the same job. I did not see any reasons make me think QSIG as the only one option ?
03-30-2015 05:47 AM
Hi Yan,
The following post has the explanation on why QSIG is needed.
https://supportforums.cisco.com/document/104091/qsig
Manish
03-31-2015 08:01 PM
Hi batts,
Thanks for your reply. so nowadays, E1 or QSIG are fully equivalent when it comes to tie 2 PBXs. If answer is no, can you provide some particular scenarios where QSIG is mandatory ?
Hi Manish, Thanks for your info, I have reviewed that URL before I posted this thread. Unfortunately, that URL did not help.
04-01-2015 01:10 AM
Hi Yan,
QSIG and E1 are not fully equivalent.They will both offer the basic functionality of being able to pass calls , however QSIG offers additional supplementary services as I described in my previous thread.
Cheers
Mark
03-30-2015 05:51 AM
Hi ,
In a way you are right , in the past I have used an E1 to tie two PBX's together due to QSIG incompatibilities, , however you have already mentioned the answer "Supplementary Services".
QSIG includes all sorts of extra functionality in regards to supplementary services, I can't go into all the differences as its all depends on PBX models etc.Personally nowadays I would always use QSIG, but you might getaway with an standard E1 depending on what you are trying to do across the link.
Hope that helps
