Wildcards and Special Characters for Translation Patterns on CUCM
Yan Tian
Hello All,
below are the supported Wildcards and special Characters in Route Patterns,
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_0_2/ccmsys/a03rp.html#wp1043520
However, according to my testing, some of those wildcards are not valid for Translation Patterns.
Can anyone tell the exact supported Wildcards & Special Charactoers for Translation Patterns on CUCM? I did not find it in any Cisco official docs.
(CUCM version: 9.1.1)
Thanks in advance.
They *should* be supported unless something has changed or this is really a bug, or the documentation is wrong, not really sure which one is
Table 6 shows what is supported for each field
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/9_1_1/ccmsys/CUCM_BK_C5565591_00_cucm-system-guide-91_chapter_010000.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
6 Replies 6
Chris Deren
Route and Translation pattern wildcards should be the same, which ones are not working for you?
Chris
Hello Chris, Sorry for the delay.
I have tried 9!, 9* and 9?, all failed with error message unsupported wildcards when I click Save Botton.
That should be a bug I think.
Hi Guys,
Pattern excepts only '+' as special character and an escape character must be prefixed like '/+4356633' .
Hi Amresh,
Just a small correction, it is backward slash (\) instead of forward slash (/).
- Vivek
Chris Deren
None of these are supported, 9! Is what you need.
Chris
java
java
