Will the Attendant console plugin from CUCM 4.1 work on CUCM 8.5?
gmgarrian
Level 4
Level 4
The subject sums it up.  My client doesn't want to lose AC functionality while the new 8.6 AC is being setup post upgrade and I was wondering if the plugin from 4.1 could work as a temp solution while the kinks are worked out of the new 8.6 install.
Thanks!
Jaime Valencia
No, not to mention that you won't find any of the AC services any longer nor the config elements you would need (pilot point, Ac users, etc).
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
That's what I figured.  Thanks for the info!
