04-07-2020 11:54 AM
I have the Cisco IP Communicator (8.6.6.51) installed on my PC. In PREFERENCES/NETWORK, I need to set my tftp. I can't get it to stick, so i have changed the tftps in the registry successfully. but i cannot get the radio button to stick ("use these tftp servers"). Is there a way I can force this to stick, either by making a registry edit, or by changing a config file. I'm sorry, but this seems to be the only way to make this work. Thank you for your advice in advance. Mark
Solved! Go to Solution.
04-08-2020 02:14 AM - edited 04-08-2020 02:48 AM
Running as Administrator should do the trick, but make sure the application is fully shut down before re-launching as admin. To play save you may have to kill the process (communicatork9.exe) from task manager. I have a couple of installs for test purposes, one on Windows 7 and one on Windows 10. I frequently change the network settings to bring them up as different instances.
Edit - if you need to swap between a couple of configurations, or just set an initial configuration, you could create a .reg file to import. Note the hex coding for TFTP server, this example is for 192.168.1.2
Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Cisco Systems, Inc.\Communicator]
"HostName"="IPC-TONY"
"TftpServer1"=dword:201a8c0
04-07-2020 12:02 PM
Try running CIPC with admin privileges
04-07-2020 12:04 PM
04-08-2020 05:44 AM
Yes, I had the app open. Ok, feel like a total idiot now. Thank you!
