Writing CDR files in FTP error
Hernan Moya
I configured CallManager to write CDR in a FTP server. The file was created but the filesize is incrementing but with the same file and if I see the file content is the same.
Jaime Valencia
where is the filesize is incrementing but with the same file and if I see the file content is the same???
CUCM?? or your TFTP???
java
if this helps, please rate
java
Cisco CallManager 5.1 writing file to a FTP Server. This is the file size 51060 and filename cdr_StandAloneCluster_01_200811121948_21001
and now the serice is down and I can't start up again.
