X-Lite 4.8.4 and CME
Jamal Ahmed
Hello All,
I will be grateful if someone can help. I am trying to get X-Lite (version 4.8.4) working with our CME. The phone successfully registers with the CME and I can make the calls out from the phone. But when I try to make a call to the phone I get an engaged tone and on the calling phone I get the message "Unknown Number"
Config:
  Mac address is 7C05.0726.204B
  Number list 1 : DN 15
  Proxy Ip address is 0.0.0.0
  Current Phone load version is X-Lite release 4.8.4 stamp 76589
  DTMF Relay is enabled, sip-notify
  Call Waiting is enabled
  DnD is disabled
  Video is disabled
  Camera is disabled
  Busy trigger per button value is 0
  keep-conference is enabled
  registration expires timer max is 3600 and min is 60
  username 270 password 270
  Lpcor Type is none
  Transport type is udp
  service-control mechanism is not supported
  registration Call ID is 76589YzQwZjUwNWQ4N2U0YTgzZWU4ZDA2MTdlMjM0ZDNmMDQ
  Registration method: per line
  Privacy feature is not configured.
  Privacy button is disabled
  active primary line is: 270
  contact IP address: 192.168.1.188 port 5060
Dialpeers created:
Dial-peers for Pool 15:
dial-peer voice 40001 voip
 destination-pattern 270
 session target ipv4:192.168.1.188:5060
 session protocol sipv2
 dtmf-relay sip-notify
 codec  g711ulaw bytes 160
  after-hours-exempt   FALSE
Statistics:
  Active registrations  : 3
  Total SIP phones registered: 4
  Total Registration Statistics
    Registration requests  : 8
    Registration success   : 8
    Registration failed    : 0
    unRegister requests    : 5
    unRegister success     : 5
    unRegister failed      : 0
    Attempts to register
           after last unregister : 0
    Last register request time   : 10:30:11.800 BST Wed Jun 10 2015
    Last unregister request time : 10:30:11.776 BST Wed Jun 10 2015
    Register success time        : 10:30:11.800 BST Wed Jun 10 2015
    Unregister success time      : 10:30:11.778 BST Wed Jun 10 2015
From the above output it seems that phone should be listening at port 5060 (session target ipv4:192.168.1.188:5060)  But if I look at the PC where the softphone is running it is no listening at  port 5060
C:\windows\system32>netstat -ano | findstr 6924 (process id of X-lite)
  TCP    0.0.0.0:51453          0.0.0.0:0              LISTENING       6924
  TCP    127.0.0.1:9002         0.0.0.0:0              LISTENING       6924
  UDP    0.0.0.0:64923          *:*                                    6924
  UDP    127.0.0.1:57121        *:*                                    6924
  UDP    127.0.0.1:57122        *:*                                    6924
  UDP    127.0.0.1:64921        *:*                                    6924
  UDP    127.0.0.1:64922        *:*                                    6924
  UDP    127.0.0.1:64924        *:*                                    6924
  UDP    127.0.0.1:64925        *:*                                    6924
I have also looked at the Wireshark traces and it seems when the CME is trying to make a connection it is getting port unreachable. I have diabled Windows Firewall and there is no other firewall running on the machine.
1 0.000000000 192.168.1.31 192.168.1.188 SIP/SDP 1198 Request: INVITE sip:270@192.168.1.188:5060 |
2 0.000100000 192.168.1.188 192.168.1.31 ICMP 590 Destination unreachable (Port unreachable)
Hi Jamal.
You don't need to create a diapeer for sip phones but you should create a voice register DN to associate to a voice register pool.
Please post the output of a show voice register pool all brief
Can you also post your CME config?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Thanks Carlo,
I didn't create the dial-peer. It was created automatically by the CME. I created the following configuration.
voice register pool  15
 id mac 7C05.0726.204B
 number 1 dn 15
 username 270 password xxxx
 codec g711ulaw
 voice register dn  15
 number 270
 name xxxx
 label xxxx
It have looked into it further and it seems to be a issue with X-lite phone as the listening port on the client (softphonw machine) shouldn't be 5060. I tried lot of options within X-lite but wasn't able to change that.
Tried a different phone (Zoiper) and it seemed to have correctly and used the correct port (session target ipv4:192.168.1.188:xxxx).
Seems there is a bug in the latest version of X-Lite.
I cannot paste the complete config can you please let me know which part of config will help
Hi Jamal.
Please post the output of following commands
show run | s voice service voip
show run | s voice register
Carlo
OK I have just confirmed that it is certainly the issue with the current version of X-Lite. I installed the version 3 and it worked fine.
Thanks for the help. I will try to get back to the company and see if they know this. I am not expecting any miracles as it is a free software.
Jamal
